yes. super simple altho a few have reported they had trouble hooking the harness up to the obd port because they have had trouble with the little locking tabs on the obd port. I have done 3 and never had an issue but i used a little pick to pop them open. I guess one draw back is you can only use it program tire size, lower the psi threshold and calibrate for gearing changes and reset CEL codes. For me that is all I need. my buddy had a few issues using it on his late built 2025 but it eventually worked.It looks like the Procal harness bypasses the security gateway by connecting to the green star connector block behind the glovebox, which allows programming directly from the OBDII port. This could be useful.
Yeah, their video and instructions lead with small screwdriver but a pick is the way to go.yes. super simple altho a few have reported they had trouble hooking the harness up to the obd port because they have had trouble with the little locking tabs on the obd port. I have done 3 and never had an issue but i used a little pick to pop them open. I guess one draw back is you can only use it program tire size, lower the psi threshold and calibrate for gearing changes and reset CEL codes. For me that is all I need. my buddy had a few issues using it on his late built 2025 but it eventually worked.
