AEV Procal snap 2024 tire size incorrect
EtBiart
ET
Long Island, NY
Jeep Wrangler Unlimited Rubicon
Aircraft mechanic
For anyone out there with an AEV procal snap on your 2024 Jeep, you may want to cross reference your corrected tire size against another programmer. Or perhaps just watch your speedo against your gps.
or maybe it’s just mine.
I have a 2024 2dr rubicon. Just had an AEV authorized shop instal an AEV dual sport lift and they installed the procal. Did a regear to 4:88 as well.
I immediately noticed my speed was slightly faster than gps. Just 2mph. I plugged in Jscan to check and noticed the wrong size. My tires are 35” ko2’s. The actual height of mine are about 34.3. Loaded on the ground. While the axle ratio is correct, the value set for tires was 35.77. The fact that it wasn’t rounded to the 10th place was the first strange thing.
i plugged in procal again and went ahead and reprogrammed 34.3. And went back to jScan. This time is said 35.73. Which kinda proved something was up.
To be sure, I used the procal to change the tire size to 35.3. After plugging back jScan, it showed tire size as 36.73. Which proves the procal was adding 1.43 for each input.
just to be extra sure , I had a tazer mini that I was planning to instal but never got around to it. I went ahead and installed it. The jScan had the same values as the tazer mini.
I don’t plan on overwriting the procal values with another programmer in fear of messing with the ECU. But I’m wondering if I should reprogram the procal snap with my actual size minus 1.43.
I spoke with AEV and they had no idea this was a thing. I’m wondering if anyone else has experienced.
jadmt
jeff
montana
I have not. the inventor of the procal (the owner of AEV's brother) told me that the most accurate way to calibrate the speedo is measure from the center of the hub to the ground when parked on a flat surface and take that number X2 and use that. my speedo and trip are spot on. are you setting your radio to AM and then watching the settings come across you center display? Mine says exactly what I set it to with the equalizer settings. was your Jscan in use before the procal? I wonder if that is causing an issue.
jadmt
jeff
montana
not sure how Jscan works but can you unmarry it and set everything back to stock and start over with the procal?
jludave
The Isle of Long
IT Manager
There is no unmarry with JSCAN. There may be an option in the app to reset everything back. I don't use JSCAN enough to be 100% sure, since I have a Tazer.
