AEV Borah wheels on JL
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
They are just nylon bolts. The protection and beadlock rings come with actual hardware where as the base wheel (no rings) comes with the nylon bolts to keep the threads clean. I had them on before I upgraded to the protection rings.
Thanks, that clarified it. I've rubbed way too many of them off in the past six months.
JLR_AEV
2020 Jeep Rubicon AEV Outfitted
Alright finally chose my final combination of wheels/tire com
Another OCD update:
Decided to give the Mickey Thompsons Baja Pro XS 35x13.5 tires a shot because of their aggressive tread and width. Still running the JL spec Borahs
1.5 inch lift
What I like about this set up is it really closed the gap between the outer edge of the bumper and inside of the tire wall and best part there is no rubbing on the LCA's even at full lock.
Just wanted to post in case anyone decided to go with the Baja Pro XS tires.
Decided my final JL/JK wheel/tire set up. And this one is for good, I promise lol
Put the JK spec Borah's back on because(in my humble opinion) I really like the 2 dr Jeeps with wheel/tire poke. Slapped on my 37 Cooper STT Pro's after reviewing 5 different tires within the last year. STT Pros were the best overall out of the KO2's, Nittos Ridge Grapplers, and Mickey Thompsons
Specs:
37x12.5x17
white AEV Borah(JK spec) +4mm
1.5 inch lift
Wanted to share this information in case anyone was going to go with this particular set up
Jeep Wrangler JL AEV Borah wheels on JL IMG_3858
Jeep Wrangler JL AEV Borah wheels on JL IMG_3857
Jeep Wrangler JL AEV Borah wheels on JL IMG_3877
Thank you all for all your contribution to this thread!
unknownsolo
Washington, USA
22 Wrangler Rubicon 4XE
I'm torn between the onyx wheel with silver ring or satin black with onyx ring for my granite crystal rubi.
Bryce
Bryce
Acworth, GA
2019 JLUR
Y'all need to stop adding damn filters to your photos so we can see how the wheel colors look irl!
Here's an untouched up pic. Sting Gray Jeep, Onyx AEV Borah Wheels and Rings painted in Rustoleum Regal Red.
Jeep Wrangler JL AEV Borah wheels on JL 20230129_225305
I took the rings off to touch up the paint prior to new tires next Saturday. I forgot how bland it looks with just the Onyx wheels.
unknownsolo
Washington, USA
Thank you! I went through this thread like six times already, and I do remember seeing yours. I have a 4xe, and your photo inspired me to do the same but in blue!
unknownsolo
Washington, USA
I received the satin black with the onyx ring today. The onyx color matches the Jeep's granite crystal color. The satin black almost matches the Jeep's OEM wheel color. The OEM wheel is a bit more reflective.
Will post more pictures once they are mounted, hopefully within the next few days.
Jeep Wrangler JL AEV Borah wheels on JL 20230203_194601764_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230203_194614333_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230203_194658550_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230203_194729085_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230203_194750776_iOS
unknownsolo
Washington, USA
The wheels were split into two shipments both were supposed to arrive today. Thanks to FedEx ruining everything, they only delivered three today, and two got rescheduled. I was able to get the spare taken care of today.
Stock are 33 KO2s, new tires are 35 KO2s. They look a lot better in person.
Jeep Wrangler JL AEV Borah wheels on JL 20230204_004811392_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230204_005003405_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230204_005042407_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230204_005057471_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230204_005104242_iOS
Jeep Wrangler JL AEV Borah wheels on JL 20230204_005211076_iOS
Bryce
Bryce
Acworth, GA
2019 JLUR
I finally got new tires. The stock KO2s made it to 44,000 miles. They would have been OK for the street but I didn't trust it for off road any more.
I went with 315/70R17 LR C KO2s this time. I do have a 3/4" spacer lift F&R.
The spare is a little tight on the steel bumper but I think after the first rotation and some wear on the tread, it'll be fine. Any bigger and I'd need to address it I think.
Jeep Wrangler JL AEV Borah wheels on JL 20230204_111650
Jeep Wrangler JL AEV Borah wheels on JL 20230204_111403
Jeep Wrangler JL AEV Borah wheels on JL 20230204_102647
4x4snowmachinejeep
2023 Wrangler 4xe White
Travel Industry
I no longer run these wheels, because the backspace would not work for my set up...however I might switch back
Jeep Wrangler JL AEV Borah wheels on JL IMG_7016
unknownsolo
Washington, USA
I got the silver rings today and just finished installing them. I think I like them more, but I keep going back and forth. The Onyx rings are very nice, too but there is no contrast. I like the color pop with the silver rings.
I also got the black bolts from Johnsons.
Jeep Wrangler JL AEV Borah wheels on JL IMG_1013
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
This may be covered in this thread, but why aren’t we using socket cap hex head bolts? And would stainless, black, or titanium, socket caps look good? I have onyx Borah’s coming and am considering Onyx protection rings.
bobholthaus
Bob
St. Louis, MO
Ratbert: care to share any pics of any wheel rash you have wheeling like you do with no protection rings? Last summer you said it’s an extra “half a grand”; it’s almost $1000 to the penny to have AEV add them at the factory (they charge $140 labor to put them on!) I ordered them today on my build, but I think they change the look so much I may forgo them.
Is it backwards thinking to not have them, and if ever they got so bad that they looked horrible, to then add the rings to make it look better then?
Ratbert
PNW
Software Engineer
This is my worst wheel. I obviously cut it too close to that rock.
Jeep Wrangler JL AEV Borah wheels on JL PXL_20230209_153045363
Note that I just washed the Jeep a couple days ago. We live just about on the side of a mountain up a dirt road, so it doesn't stay clean.
I'm guessing that it might look worse if the rings were there since they protrude even further out.
Is having them better than not in the long term? No clue.
