AEV Borah wheels
NewTXJL
Dallas, TX
2019 JLUR
Just ordered Borah's. Can someone confirm that these will work on my JLUR with a 3.5 MC lift without spacers? I have 315/ 70 R17 BFG AT KO2's. Pictures of how they got would be great. Thanks.
NTX Black Moab
Tom
DFW, TX
2019 Jeep Moab (Black on Black)
Pretty sure these have a 3.5" backspace. If so, they'll work with the vast majority lift / wheel setups.
MntsRcalln
Virginia
2020 JLUR, 2011 Dodge Ram Bighorn, 1990 Totoya 4x4 Mod
Same wheels and tyres on AEV 2” lift with Rubi shocks and springs to gain an extra inch. Paul
Do you have the Galaxy Black with the Onyx ring?
Thanks
SSinGA
Sean
Alabama
2018 JLUR, 2016 JKRHR, 2012 JKU Sahara
NTX Black Moab
Tom
DFW, TX
MntsRcalln
Virginia
Yes, I wanted all black originally but I think they turned out OK
You made the correct choice I think. I like the slight contrast difference in the wheel and ring. Plus those silver ring bolts make it pop.
SSinGA
Sean
Alabama
WOW. That backspacing would make it a challenge on my rig. RK recommends 3.5 and I know I rub with 4.5 BS.
MC recommendation is due to the relocated shock mounts but isn't clear if this statement is for all JL or just Sport/Sahara and the Rubicon number is slightly less due to the wider axle length.
"IMPORTANT NOTE: If using OE wheels 2" spacers will be needed to give proper clearance. These mounts are intended for use for wheels with 4.5" of backspacing or less or an equivalent of a 2" spacer on factory wheels."
NewTXJL
NewTXJL
Dallas, TX
2019 JLUR
Ok...I just spoke with MC and looks like i have to cancel this order..!!! Likely not going to work without spacers.
Thanks everyone.
SSinGA
Sean
Alabama
Thanks everyone.
Why not just add spacers?
Is the 4.5" backspace a requirement for the Rubicon and other models need more?
NewTXJL
NewTXJL
Dallas, TX
2019 JLUR
I am upgrading the wheels so I can get rid of the spacers to begin with...
I know there have been several discussions on spacers yes or no...
SSinGA
Sean
Alabama
What if you used the AEV Borah for JK. 4.9" backspace on those
NewTXJL
NewTXJL
Dallas, TX
2019 JLUR
Hadn't considered that...will look into it. They suggested 4.75 to be safe and have options to go bigger tires in the future. Thanks.
SSinGA
Sean
Alabama
On My JK, MC said you needed 4.5" BS wheels but I ran AEV Pintlers (5.2" BS) with 35s and had no rubbing.
D&C Designs
