Advanced Safety System Plastic Box PN
nU7OuxIx
Chicago
2025 JLU Rubicon X, YJ, Impreza
It's a long shot, but does anybody know what the part number is for the plastic box that goes around the advanced safety system? There's a rubber gasket at the front of it.
The wonderful techs at safelite decided to hack the rubber gasket up that goes around the box. Another surprise I discovered this past weekend while detailing the jeep. It's like the tech thought that the box was glued to the windshield so they took a razor blade to cut the rubber gasket out. I don't know if they removed the old window with the string method, suction and drill...and maybe the string cut the gasket up?
I'm just guessing the gasket is there to protect the sensors inside the box. So far, I've been unable to locate the part number for it and I don't know if I will be able to. I really don't want to try the junk yard option but I may have to.
nU7OuxIx
Chicago
I search and can't find it. Then I post, search again and find it.
If anybody else is looking the part number is 6QD20TX7AB.
Second question...does anybody know if this is an easy part to swap out? Is it just the push pins that pop out and the box falls off? Does it throw calibration off at all?
Thank You!
jadmt
jeff
montana
just looking it looks simple...the one thing I would order extra pushpins as I have had the worst luck with those kind that have the little plastic phillips heads..maybe these will be better but in the past those things just strip out and they don't unscrew so you end up bugger them all up.
