A quick question about gasoline smell.
Aranimus
CA
2018 Wrangler JL Sport S
Hi guys,
This may be an entirely stupid question (not being a mechanic and all), but I thought I would ask. From a cold start, when I move my JL from the driveway into the garage (or vice versa, backing it out into the driveway), I smell a fairly strong gasoline odor. It's sharp, and not what I would expect from errant exhaust fumes. I was wondering whether this was normal, and perhaps just a result of incomplete combustion from a cold start? I mean it's not a big deal, but I notice it quite often. No leaks, everything functions perfectly, so perhaps I'm just noticing something I hadn't before (in previous vehicles) since I finally cleaned my garage, and can finally fit a Jeep into it!
--Bill
GreyFox
Brandy
Ohio
17 JKU, 19 JL
Mine starts in a garage also and this is normal. Well, for me anyways. I have noticed it in other vehicles that I keep in the garage. I'm sure a more knowledgeable person will comment on the actual science behind it:like:
Placebo
Bay Area
Something with 4 wheels
When you do a cold start, the engines run richer because cold gas is harder to vaporize and cold gas can condense. So what pretty much every single car does, is they run a super rich air fuel mixture to prevent any issues during a cold start. It's so rich that sometimes all of the fuel doesn't burn up and so you smell gas when you start your jeep in the morning.
Edit: I should add that this is normal behavior for cars on cold start. Now if you smell gas and its not a cold start, then maybe you should think about if you spilled any gas onto your jeep from the gas pump or if you have a leak somewhere.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Definitely normal for a "cold start" especially if ambient temps are below 50ish or so. My wife's JLUS and my former Charger R/T run rich on startup, especially in the winter months. I just got my own JL 2 weeks ago and it's been nice and warm so I can't comment on mine yet, but I imagine it will do the same thing.
Rahneld
Ronald
Boston
JL Wrangler
A somewhat sidetracked quick anecdote.
The engine light went on in my Wrangler. I brought it to the dealer who it seems properly diagnosed that I had not tightened the gas cap adequate: no less than 3 clicks.
I didn't smell fumes but the dealer's diagnostic equipment did detect them from the gasoline filling port until the cap was tightened. This leak was also detected by the rig's systems which then actuated the aforementioned engine light.
Aranimus
Aranimus
CA
Hey guys,
Thanks for the replies. From what Placebo and The Fixer said, I agree that it's just normal, and I guess I was just noticing it for the first time because I am now pulling it into the garage! Just goes to show, cleaning your garage will lead to confusion!
--Bill
PS. Rahneld, it seems odd that not tightening a gas cap would lead to some electronic diagnostic issue. After all, if an engine's performance depends on consistent air pressure or containment at the point of the gas cap, I would think all vehicles on the road would have problems!
telix
Roseville, CA
2019 Granite Jeep Wrangler JLU Rubicon
I also have a very strong gas smell when starting from a cold start. It doesn't seem quite right
Notorious
North Texas
2000 TJ Sahara
Maybe lay off the refried beans at dinner? :CWL:
Try filling up at a different branded gas station and see if the gasoline still smells. Otherwise it is as the poster above mentioned.
Paluss
maryland
2022 JLURD
Interesting, not experiencing a gas smell at all and my JL is 2 years old. In the winter I remote start for a few minutes before I enter the garage and the garage door is closed, but I don't notice any gas smell. Now I do get a gas smell from my motorcycle which has an open air filter, but the JL air box is a closed system, may be worth a check by the dealer.
Maverick909
I.E.
the fuel tank is pressure tested by the ECU. they do a leak test to make sure there is not anything wrong. when the fuel cap is not tightened correctly it will show a check engine light because of it. all new cars are setup for this
As Placebo stated last August, fuel does not vaporize well at lower temperatures. When the engine is cold, the fuel will attach to any surface it comes in contact with. Liquid fuel emits less and less flammable vapor as the temperature goes lower.
With a carbureted engine (I'm old) the fuel is atomized in the venturi discharge and then contacts surfaces from the throttle butterfly, intake manifold, ports, valves and cylinder head, cylinder walls, etc.. When it contacts a cold surface, it attaches and forms larger droplets and flows along the surface. Cold fuel does not emit as much vapor which mixes with air to form a combustible mixture. This makes it harder to ignite. These old carbureted engines had a "choke" that richened the mixture a lot in order to get a combustible mixture in the combustion chamber. It took a long time for the intake tract from the carburetor venturi to the combustion chamber to heat up, thereby allowing the engine to run with a leaner mixture.
When port fuel injection came along, the injectors were closer to the combustion chamber and there was less contact with the surfaces along the path to the combustion chamber. Also, many engines are designed with the injector very near the valve, which allows spraying fuel directly into the chamber. This helped in that less fuel was deposited on surfaces along the path to the chamber, which lowered the amount of fuel that got sucked into the chamber once the engine started. Since the injector is nearer to the combustion chamber, the surfaces downstream of the injector heat faster/sooner allowing fuel to vaporize. Better.
When direct injection came along, no fuel was deposited on surfaces along the path to the combustion chamber. All the fuel is metered into the chamber itself. Still there are cold surfaces in the chamber (head, cylinder, piston), but they heat rapidly once the engine started. So a direct injection engine still needs a rich mixture to start and run for long enough to heat those surfaces, but that is measured in seconds now instead of minutes. Better still.
Worth a read. https://www.businessinsider.com/her...-doing-to-your-engine-and-its-not-good-2016-1
If I lived in a cold climate, I'd use a full synthetic oil that had good cold lubricating qualities. If it was extreme cold, I'd use oil pan, block, transmission, differential heaters Then I'd stop worrying about a long slow warmup.
