Ron93YJ
- Ron
- Feb 10, 2021
- Pittsburgh, PA
- 2021 Rubicon 4xe
87 octane 4 Life
Same here.My JLU has been fed 91+ since the day I took delivery. No complaints.
If the gas is good enough (as in it's actually 87), the computer is designed to limit what the engine will do with it, so it's fine. This is also assuming that everything is in good working order, which it should be until the vehicle ages--especially with GDI. If (when?) things get gummed up, you effectively have more compression and greater potential for pre-detonation ("knock") which the computer may or may not be able to handle. So, a firm "probably not bad now, maybe not ever" ?On a side note. If you run 87, what happens that is bad? I really want to know as I have never had a real explanation.
I am in the same boat. I want to take as much care of my engine and the few cents extra is more than worth it.If the gas is good enough (as in it's actually 87), the computer is designed to limit what the engine will do with it, so it's fine. This is also assuming that everything is in good working order, which it should be until the vehicle ages--especially with GDI. If (when?) things get gummed up, you effectively have more compression and greater potential for pre-detonation ("knock") which the computer may or may not be able to handle. So, a firm "probably not bad now, maybe not ever" ?
I like performance and I also look at it this way: gas is cheap; engines are expensive.
John,On a side note. If you run 87, what happens that is bad? I really want to know as I have never had a real explanation.
I don't believe anything bad happens. A lot of modern engines can compensate for lower octane. Higher octane gas isn't really better...it is just needed in higher compression motors to prevent pre ignition. Think about how water will boil at a lower temperature at altitude (lower atmospheric pressure). It has a different boiling point depending on surrounding atmospheric pressure. Different octane fuels will ignite at different temps depending on compression ratios. With a higher compression ratio, lower octane fuel can pre ignite (ignite from temp in the cylinder chamber before spark is given) and cause knocking in your engine, which can cause problems over time. A higher octane fuel will not pre ignite and allow your engine to operate at peak efficiency. If your engine senses a lower octane fuel is being used, it will retard the timing of the engine. This will change the timing of when the fuel/air mixture in the cylinder chamber receives the spark in relation to the cylinder's position within that chamber. This will reduce the compression ratio, preventing pre ignition. Of course, this will reduce the power of the engine as well. It may reduce the fuel efficiency of the engine. I'm not sure how much HP you will lose with 87 octane in the 2.0. As an example, however, in the Bronco, the 2.3 eco boost is rated at 300hp on premium fuel and 270 on 87 octane. So you can run 87 without causing damage, you'll just give up 30hp. I'm not sure if this is a perfect explanation. I'm sure there are mechanics and engineers out there that could explain to better.When gas is cheap, you use 91. When it's expensive, then 87.
If you have an RV, it's really fun as you have to reset the pump at least once as most are still at that $100 limit (some are $125).
This assumes it's exclusively an engineering decision; it isn't.Well, we're old whippersnappers in our 60s and ours gets filled with 87. If 87 octane caused any problems to the 2.0 engine the engineers would not have stated in the owner's manual that it was OK to use. We plan on keeping it for at least 10+ years.
They compensate after the fact. IOW, after a knock, the PCM realizes "Oh, I shouldn't do that" and backs off.I don't believe anything bad happens. A lot of modern engines can compensate for lower octane.
You will get more horsepower at higher rpm’s and potentially get better mpg because the engine can advance the timing. Will you see an increase equivalent to the increased price, absolutely not. Our Mazda is rated for more horsepower with 91 but the torque ratings are the same, I see 0 difference between fuels. My VW requires 91, I could get away with 89 at my elevation but it’s definitely worth the extra fuel cost with the tune. I’ll likely tune the 2.0 in the wrangler and see how I like it, the SRT tune seems to be lacking torque but it makes reasonable horsepower.The owners manual on my 20 states the engine is designed to run on 87 octane., with higher octane recommended for maximum performance. Mine from the dealership has never had anything other than 87, runs great, gets very good mileage (esp for a Jeep) and has all the performance I want or need. I have no intention of running anything else, period. The oil folks make enough per gallon at best. anything above what an engine is designed to run on is basically a waste. Yea, I know folks say the get more power, better mpg’s etc on 93, but I truly wonder if that’s real or placebo effect. IF I was having any issue with knocking or similar I “might” try something different. Certainly if the owners manual requires 91 or 93 that’s what you should run, however with the Jeep it is NOT a factory requirement. Certainly the engineers that designed the thing should know what fuel is required. I will NEVER again buy any vehicle that requires high octane fuel. YMMV
