BXFXJeep
- Jun 13, 2019
- Toronto, ON
- 2021 4xe Sahara
99 Sahara Desert Sand96 TJ ? That’s a unicorn right there
actually, 1st is pretty low .... the real problem is the gutless car motor they use in the wrangler.Completely agree, and then they could make 1st gear a little bit lower so I don't have to slip the clutch so much when starting out on a hill. And that reverse....my gawd......why is it so high geared? If you're backing up the hill you either slip the hell out of the clutch while revving it up, or lug the engine down and it sounds like a dying aardvark, or you kill it. WTF jeep??????? Who needs to drive 35mph in reverse???
I need more coffee. haha
HAHA we need to have a beer sometime for some bench racing........actually, 1st is pretty low .... the real problem is the gutless car motor they use in the wrangler.
my 78 landcruiser first is 3.5:1 while the rubicon is 5:13:1.. but the landcruiser makes DOUBLE the torque below 2000rpm than the wrangler.
in fact, the 2F in the FJ40 puts peak torque out at 1800 rpm... so while it has a much higher first gear, just lift the clutch and it moves off at walking speed with no skinny pedal. you can actually row through the gears never touching the gas and you will end up in 4th at about 15-20 mph just idling along and that tractor motor wont care one bit.
#RUBICONNEEDSAHEMI
True. I realize the frontal crush zone is important so they can't use a longer engine, well unless they stretched the front end but I guess we don't really want that. Maybe just a V6 with a much bigger stroke would be the ticket? Probably hard to make it as fuel efficient then, I suppose?@8flat,
I'm with you there, brother. An I6 or small 8 would be perfect...but neither fits due to safety reasons, which is too bad. I dont hate the 3.6 (i have an older porsche that is also gutless off idle so im kinda used to dealing with it), but the rubicon would be so much better with a motor with a torque curve lower down in the rev range.
Haha very true, I was literally just bragging this up yesterday. Very lucky to be able to get a manual these days...in anything.....hell the corvette is dropping the manual option. Unreal.Eh, we are just nit picking. Love the fact that i can get a stick at all
so, i had to back all the way up my driveway this weekend with a pretty heavy load. it's got a slight incline and we normally park front in and just let it roll back in neutral to exit .....@8flat, you are absolutely right! no grunt at idle in reverse and it stalled.. with any gas you go waaaaay too fast unless you slip the clutch. not a fan of that at all.Completely agree, and then they could make 1st gear a little bit lower so I don't have to slip the clutch so much when starting out on a hill. And that reverse....my gawd......why is it so high geared? If you're backing up the hill you either slip the hell out of the clutch while revving it up, or lug the engine down and it sounds like a dying aardvark, or you kill it. WTF jeep??????? Who needs to drive 35mph in reverse???
Well, I should point out it's not confirmed officially, but all the leaked info so far about the new mid-engine vette is there will be no true manual option. Dual-clutch arrangements with paddle shifters, likely.Wait...no way?!?
I've had my JL for about 4500 miles and I consistently get 20-MPG combined. I think this is only because I use 5th and 6th whenever I can to save on fuel, plus I don't drive like an asshole. I know my Jeep isn't a sports car so I don't try to drive it like one.Yes, you are absolutely right. I can’t believe for a second that anyone is getting 22mpg in a wrangler, unless they are driving 45mph, down hill in neutral. But at some point, you have to go back uphill.
