MORTON
Approx Install Time .50 mins. It took me (1) cigarette and .50 of a beer.
Rugged Ridge 2” Tow Hitch Receiver Features:
You will be provided in the kit the following:
First, layout your kit and ensure all hardware required has been provided as shown below:
Next, locate the frame crossmember behind the rear bumber cover and identify the (4) holes on the crossmember you will be utilizing:
Next, you will need the following hardware and tools:
Hardware:
Should look like this (in this order) before inserting:
Next, hold the Receiver Hitch up to the crossmember align all holes and insert the (2) Hex Bolts mentioned above into the (2) center holes and begin threading by hand.
*NOTE: There are (2) welded Lock Nuts on the backside of the (2) center holes on the Receiver Hitch as shown below:
Once finger tight begin using your Ratchet. Tighten until snug but still allowing Receiver Hitch to move freely.
NOTE: There is grease in the (2) center welded Lock Nuts. Once snug use your finger to spread the grease on the excess threads:
Hardware:
Should look like this (in this order) before inserting into the (2) outer holes:
Next, insert the (2) Hex Bolts into the (2) outer holes. Should look like this (notice the addition of the (2) outer (far left/far right) Hex Bolts:
Once through, on the DRIVERS SIDE OUTER BOLT, slide the Trailer Wiring Harness Bracket onto the Bolt.
Then slide your remaining Flat Washers onto both Hex Bolts and hand thread your (2) Nylon Lock Nuts:
Tighten all down until firm (German tight) both the center and outer at this time:
And you’re all done!!
BIG shout out to @Northridge4x4 @Tech Tim for the kit at an unbeatable price! Thanks for supporting our community and forum!
- Heavy Duty 2-Inch Receiver Hitch
- Designed to Match JL Towing Capacity
- Capable of 3,500 Pounds Towing Capacity
- With Tongue Weight of 350 Pounds
- One-Piece Welded Assembly
- Black Powder-Coat Finish
- Bolt-On Installation
- Five-Year Limited Warranty
- Fits 2018-2019 Jeep Wrangler JL Models
- 19mm Open End Box Wrench
- 18mm Standard Socket
- 3/8” Drive Ratchet
- Wife’s Yoga Mat
- x1 2” Receiver Tow Hitch
- x1 Trailer Wiring Harness Bracket
- x4 Hex Bolts
- x6 Flat Washers
- x2 Lock Washers
- x2 Nylon Lock Nuts
Hardware:
- x2 Hex Bolts
- x2 Lock Washers
- x2 Flat Washers
Hardware:
- x2 Hex Bolts
- x4 Flat Washers
