[4xe recall] Sand contamination during the block casting process? Seriously?
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
cansberry
Connor
2023 4xe Willys
Foreign manufacturers always seem to be held to a higher standard by the government than the Big 3, which might be why the Big 3 have a tendency to pump out 💩
Voluntarily done by Toyota. Japanese business ethic just beats the crap out of ours.
AZpueblo
AZ
2019 JLUR, ‘24 JLURX 4XE
I take an oil sample and lab test it on all my vehicle when I change the oil, just looking for things like this. None of my past oil test show high silicates, which might indicate evidence of sand. As a side note, if the airbox isn't properly sealed you might see high silicates as sand leaks into the intake. Since my tests have been clean, I'm not too stressed about this issue.
AZpueblo
AZ
From the NHTSA recall:
"Between May 2025, and August 2025, FCA US has analyzed available vehicle data such as
warranty claims, repair orders, and field incidents to determine root cause. FCA US has also
conducted multiple engine teardowns and determined the presence of sand within the engine
block. FCA US identified a period of time between June 2023 and March 2024 at the engine block
supplier, where the engines were not properly cleaned following the casting process. All reports of
engine compartment fires and loss of propulsion incidents have engines built during this suspect
window."
My '24 was built June 6, 2024 so pretty sure I'm in the clear (and my oil analysis reports confirm very minimal silicates).
DaltonGang
Doesn't Play Well With Others
Early, and frequent oil changes, until they figure this out. It could be that so much sand is still inside, and breaking loose, throughout the engines life. This would be a "Worst-Case Scenario".
WI_Sarge
WI
2024 wrangler sport S
Now this in addition to the bulletin earlier this year for blocks being cast to porous and failing. WTF. Now they gonna crank up to 315 hp with some crazy injection system? Take my printed mopar extended warranty and cuddle with it at night now instead of my wife.
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
window."
When your vehicle was assembled and when the block was completed could be very far apart, depending on how much inventory is being held throughout the engine and vehicle assembly processes. If anything, I’d say chances are higher yours is not in the clear.
I also don’t really believe this 4xe-specificity… A 2.0T is a 2.0T. There does not seem to be a difference beyond the assembly plant. The blocks presumably come from the same supplier/plant.
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
Well, those dates explain why I haven't gotten this particular recall... yet.
Ratbert
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
From the article:
Naturally, all affected vehicles will ultimately be serviced, but owners are not expected to be notified by mail until December 29.
JayJLU
Jay
SE Pa
Wrangler, Gladiator, XJ Cherokee
Only the 4XE? Are those 2.0Ts built in a different factory/ area/ process, than the non-4xes? Or are the turbos different?
Not a good look. Engine recall and battery recall within the same month.
One should look at / read about all the Ford -
GM and Toyota recent recalls before being concerned about LOOKS
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
I would think that it has to do with parts manufactured outside the USA. Found this on the interweb: JEEP engines manufactured: * **2.0L Turbo:** Some say Trenton, Michigan, and Italy. * **3.6L V6:** Built in Dundee and Trenton, Michigan, and Saltillo, Mexico. * **HEMI:** Designed in the US, but built in Mexico. * **EcoDiesel:** Designed and built in Italy.
I see a trend here, but it could just be me. Though in my 60 years I have not seen recalls with regards to ICE vehicles in the U.S. at the numbers we have now. And also spontaneous combusting batteries. The insanity will continue until mfg’s feel more pain. How much pain will it take? Unknown, I believe it depends on board members and investors. Globalists suck.
Perhaps so. I suspect it has as much to do with cost-cutting money types. I worked with a purchasing agent who would spare no cost to save a penny.
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
On the window sticker it says country of origin for the engine and transmission. On my 4xe, the engine is from the US.
I believe that globally sourced parts are the problem. I also believe the tappet problem in the 3.6L is a material deficiency not an oil lubrication problem.
BXFXJeep
Toronto, ON
2021 4xe Sahara
.........and planned obsolescence, also long gone are the days when vehicles are built to last long beyond their warranty.
Like everything else, automotive sales today is mostly about selling massive perpetual debt, than it is about selling an actual decent product.
Your vehicle have a failure? no problem, here's a new one, and you get 5 year warranty for the engine, oh look the screen is bigger than the one in that failed 3 year old 💩 you have now......shiney, me likes....
We will roll in what you owe on your old junker, your payments are only $271 a week for a new car.
But I was only paying $125 a week for my car
Yeah, obviously that is why it failed on you, you get what you pay for, it sCiEnCe.
cansberry
Connor
2023 4xe Willys
But the sand is left over from casting the block. Which originates in the US. Which means it's US manufacturing that messed it up. It's not like it's a secret that "American made" hasn't meant jack in terms of quality for at least 30 years.
