4xe Hitch options
Zombienation
Doug
South Jersey
2021 4xe Sahara stingray
Looking to hear what 4xe owners are using for an aftermarket hitch. Seems not all jl hitches work. For example the Quadratech one says not for 4xe.
just need it for a bike rack and dirt bike carrier. Easy install preferred!
Krones
Oregon
2021 4xe Sahara
I'm not sure why it says the Quadratec 2" receiver hitch won't fit. I bought it for my '20 JL Willys, and when I traded it in I took it off and put it on my '21 4xe Sahara and it fit just fine. Very easy.
DurangoRob
CO
Subaru Crosstrek
I was just looking at this same topic as well, and I came across this post from last month, and there were other users who also had success with the Quadratec hitch and harness.
LINK to POST
Zombienation
Zombienation
Doug
South Jersey
Ya, pretty strange they would list like that when apparently it fits. What is actually different on the 4xe vs normal Sahara hitch area?
C2D2
2019 Jeep Wrangler Rubicon
I purchased a Rubicon take-off receiver to put on my son’s Sahara 4XE. It fit perfectly if this helps. Both are/were plastic bumpers but I don’t think that makes a difference.
Equitasforall
Virginia or Tennessee if in the US
2021 Rubicon 4xe
I could tell you, but then....
Went MOPAR with mine as I'm taking the Jeep with me overseas later in the year and had to keep all mods OEM to avoid trouble on import permits. Went on in 15 minutes with no issues!
Zombienation
Zombienation
Doug
South Jersey
Sounds like the consensus is most will work, going to pick one up and give it a shot
PolyFan
Charlotte, NC
Jeep Wrangler 4xe Sahara
I'm seeing $88.25 at this URL... and I want to ensure the hitch works with the stock plastic step bumber. I hear Quadratec specifically references which on to use with the step bumper.
fcsallan
Allan
FL
2022 Jeep Wrangler JL 4Xe
Manager of ones and zero's
It changes nearly daily, todays price:
Jeep Wrangler JL 4xe Hitch options hitch
TK8286
North Carolina
2021 Rubicon 4xe
this is a no brainer.
Trailer Tow Receiver Kit - Mopar (68240905AA)
$58.99
https://store.mopar.com/oem-parts/mopar-trailer-tow-receiver-kit-68240905aa?
This is the one I used on my 2021 rubicon 4xe. I have Rubicon steel bumpers. It works with no issues. It pained me, but I did order two molar bolts. I could have sourced them locally, but I wanted them to match and the look like they are galvanized for corrosion protection.
There was a spacer plate between the rear cross member and the steel bumper. It came out and the hitch plate replaced it.
The descriptions were confusing as to whether they fit. This part number does.
RleeA
Ryan
MA
2022 Wrangler 4xe
just installed this Mopar hitch on my ‘22’ 4xe Sahara w/plastic bumper. Really easy install. Need to torque to 67 ft/lbs if using it for anything other that a bike rack.
https://www.cjponyparts.com/mopar-hitch-receiver-assembly-kit-jeep-wrangler-jl-2018-2022/p/82215209/
Zombienation
Zombienation
Doug
South Jersey
Update to an old thread:
Picked up the Tyger hitch from Amazon based on a lot of reviews. Tyger Auto TG-HC2J003B Hitch & Cover Kit Compatible with 2018-2022 Jeep Wrangler JL/JLU (Incl. 2020-22 Diesel engine/21-22 4xe) Factory Style 2 inch Rear Receiver Hitch Tow Towing Trailer Hitch https://a.co/d/bPBx2hA
Install was super easy as long as you follow the instructions and use the right tools. I needed a big ratchet to break the factory bolts loose then my electric ratchet to finish. With the bracket be sure to remove the small bolts to loosen it to fit in the hitch. YouTube is always helpful. This is mainly going to be used for a bike rack.
Jeep Wrangler JL 4xe Hitch options 44052760-F9A9-486F-989F-B3AFDCBC2659
SOON
Roseville CA.
JL Willys 4XE
I just got a Willys 4xe this week. I’m looking for a hitch to put on. For right now just to carry a couple bikes. But I’d like to have one with a wiring kit to eventually tow a jet ski. I’ve heard debates about being able to tap into the break lights or having to run the wiring all the way up front. I apologize if this question has been answered in another thread. Couldn’t find it if it’s out there.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Bit of a combo. With the LEDs, you cant pull full amps for the trailer circuit from the tails or you'll error out. The four flat kits will pull all the signal from the tails, but will need a 12 volt source to provide the relayed power to the trailer lights. Normally this means a single wire run to the battery positive.
