Rubicon 4xe springs on Sahara 4xe?
Sesto1331
Andy
Snoho WA
2021 4xe Sahara
Greetings. I recently moved from a 2018 Jlu to a 2021 Sahara 4xe. I’m looking to build a mild setup for my new Jeep. I’ve started with swapping out the factory 20”’s for a set of 285/70/17 bfg’s on method wheels I’d like to give the Jeep a mild lift so that it can handle the extra weight when I add f/r bumpers and winch. Has anyone done a spring swap from a rubi 4xe to a Sahara? 4xe? If you did, did you gain anything? I know in the non 4xe versions, this spring change would net about 1-1.25” of height. Is this the case for the 4xe as well?
thanks in advance
Sesto
Jeep Wrangler JL Rubicon 4xe springs on Sahara 4xe? 14444F92-7EB9-45AA-A8EB-1C98B92D6BB0
Upnover
Michigan
None
IMO unless you hate the ride, I would just do the TF 1.5", and 2" stock extensions and some mopar longer control arms to be all set. I think the stock rubi is a little floaty. When I added the LCA to my last JL it road much better. All in at about $350.
Sesto1331
Andy
Snoho WA
2021 4xe Sahara
Thanks. I’ll look into that.
