3D Designer Section for 3D Printers
ArcadeTracks
PJ
Pittsburgh, PA, USA
Have any of you printed (pre-2024) vent covers?
I have some I like -- they sort of curl around the inside and outside of the four front vents (instead of just sticking flat to the fronts) but they're blue, and I'd like black. I used Plasti-Dip, but it's peeling since we adjust the vents. Online sets are $15-$25, and it looks like most are those thin ones which leave the interior and exterior sides exposed. I thought maybe one of you 3d printer pros might have some + a link to your etsy (or whatever) shop.
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
made a 25mm x 13mm bump stop for my DV8 rear molle panels to keep them from rattling against the roll bar at the front. You can use/tweak for whatever; uses an M4 socket head bolt, a M4x6 heat set insert, PETG, and TPU.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
More 3d designing/printing fun for Jeep ducks. A "no tape" secure dash display.
Also posted more images here:
https://www.jlwranglerforums.com/forum/threads/jeep-related-3d-print-files.122779/post-2637482
Had some time over the holidays, so I designed some add-ons to my no-tape/friction fit duck holder. This brings the capacity to 10 ducks. I realize ducks aren't for everyone, but I know my wife really enjoys the whole thing.
https://www.thingiverse.com/thing:6910088
Jeep Wrangler JL 3D Designer Section for 3D Printers Screenshot_20250122-074212_Chrom
RudeJeepin
Carl
Washington
2021 JLURD
Designed my own 3D printed Method 305 wheel protection
That's pretty slick. You could do multiple different colors even.
If you don't mind, I'd make a suggestion for a slight change. Instead of a 90 degree splice, how about a lap joint. As in, see white line...
Jeep Wrangler JL 3D Designer Section for 3D Printers IMG_20250408_094238~2
shagles
Skylar
2020 JLU Sahara
adult toy engineer
I agree. The bolt going through both pieces will prevent any kind of gap opening up from temperature changes.
KU310R
Malta
2024 Jeep Wrangler Rubicon Unlimited RHD
I appreciate your recommendations guys. This was my first time that I looked into 3D printing, and in order to get to this I had to learn some basic Autodesk Fusion and print a couple of sample models in order to get the final design to work. Then found a local company who 3D printed them for me.
I have already printed 50 pieces (to cover all 5 wheels plus 10 extra) sanded them by hand, primed them and raptor coated them. So for the time being I will keep them as they are, but will keep your suggestions in mind for any future projects.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
No worries man. Just a suggestion, definitely not a "do this or it'll never work."
If that's your first go at 3D modeling and printing, solid job. Matching diameters and hole locations on a diameter is no easy task without some somewhat specialized measuring tools.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
Not sure if this is quite what you're looking for, but i printed one of these for the driver side of the defrost vents. It works pretty dang well. The snaps need to be tweaked a little bit, sometimes my sun shade will knock it off. Super easy to put back though.
Jeep Wrangler JL 3D Designer Section for 3D Printers 1746458535312-y3
Jeep Wrangler JL 3D Designer Section for 3D Printers 1746458558780-gl
KU310R
Malta
Cheers mate! Yeah somehow a managed to make it work using mostly a ruler, and cardboard modelling. However when it came to aligning the holes I had to give a bit more wiggle room than the actual bolt size.
Htfan
Orange County, CA
Designed a Rocklight Mount that utilizes the existing/unused threaded hole just under the driver side & passenger doors. I wanted a courtesy light to assist stepping into the jeep on dark nights when on uneven ground/rocks. For the 12v source I tapped into the driver's side footwell lighting. It has a "soft" ON/OFF and comes on when remote unlocking or manual opening of the doors.
Jeep Wrangler JL 3D Designer Section for 3D Printers Rl1
Jeep Wrangler JL 3D Designer Section for 3D Printers Rl2
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Did you upload it to a file sharing site like Thingiverse.com by chance?
