smarshall
If anyone has the ARC door hangers and access to a 3D printer here is an adapter that can be used to hang tube doors.
These allow the tube doors to be hung on a wall and safely stored while not in use. Shown are the Rugged Ridge tube doors but others may fit. The diameter of the tube holder cradle is 50mm which should work for tube sizes up to 2". The adapters have a bottom slot which fits over the outer lip of the hanger and by centering the cradle over the lip it hangs the doors further away from the wall. The STL file is posted on thingiverse. I ran out of filament half way through the print which why they are 2 colors. The print time was 36 hours with 50% infill but I think it can be shortened significantly by using a infill of 20-30%. 50% was overkill.
