38" Tire options?
dogslbr
Jason
West Virginia
23' Rubicon XR
Looking to move up to 38" x12.50 or 38" x 13.50 x17" . Currently on 37" Mickey Thompson Baja Boss MTs and really like this tread but unfortunately MT doesn't make a 38" so I'm looking at options, prefer to go with a Load Range C or D, In an MT or possibly RT type pattern. Am I missing any in this space? There isn't a ton of options but definitely more than there used to be.
Nitto Ridge Grappler 38x12.50x17, Load C , 82 lbs
Nitto Trailer Grappler 38x13.50x17, Load D, 90 lbs
Falken RT 38x13.50x17, Load D,87.3 lbs
Falken MT 38x13.50x17, Load D 92 lbs
Toyo RT Trail 38x12.50x17, Load C, 80 lbs
BFG KM3 39x13.50x17, Load C, 87 lbs
* I know these aren't 38s but BFG tends to run small and I think installed are only about 1/2" taller than most 38s.
Milestar Patagonia MT/02, Load D, not sure on weight.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
Is 3-Peak rated a concern for you? I'm pretty sure nothing larger than a 37 has it.
BFG KO3 39x13.5r17 Load range D - 3pmsf rated
77.3lb weight. Likely a true-size/taller 38 than a 39
since its a KO3 i bet this is going to be only as tall as what a Mickey Thompson Baja Boss AT 38 would have been with higher tread depth (18/32 vs 15/32).
Jeep Wrangler JL 38" Tire options? 1770706752185-39
dogslbr
Jason
West Virginia
23' Rubicon XR
3 Peak rated isn't a requirement for me. We get a fair bit of snow but I typically don't drive the JEEP much in the winter. I wouldn't sacrifice offroad capability to get a tire that is 3 peak rated if that make sense. I have ran Mickey Thompson 37" Baja Boss ATs that are 3 peak rated and the difference is noticeable in the snow & ice. If that tire was available in a 38 it would be a strong contender. Its very good offroad, except for deep mud, for what is pretty a pretty tame tread pattern. The Falken RTs look really similar to them except w/o as much sipping-----probably why they aren't 3 peak rate like the MT BB.
Twisted10
Brandon
Western NY
2023 Wrangler 392 XR/2022 Ram Cummins
My milestars have been fine.
Jeep Wrangler JL 38" Tire options? jeep38
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
BFG's claim of 38.5" overall diameter is pretty accurate. I took some measurements of my 39" BFGs before mounting them on my Jeep. Mine measured 38 5/8" tall mounted on a Teraflex Nomad 17x8.5 wheel with 30 psi in the tires.
Jeep Wrangler JL 38" Tire options? Tires 39 BFG
Here is a 40" Toyo, compared to a 39" BFG, compared to a 37" Cooper.
Jeep Wrangler JL 38" Tire options? TIres
dogslbr
Jason
West Virginia
23' Rubicon XR
Good to know.
Did u happen to take a measurement installed with the weight of the JEEP on it? Nitto 38s seem to run about 37" installed@street pressure by most accounts ive read
3TV
Southwest USA
Good to know.
I have not taken that measurement. Everyone's Jeep is going to weigh different, and mine is a lard ass with all of the recovery gear, tools, and survival gear I carry.
