2WD Low transfer gearing
Zuni
Rome, NY 13440
2023 Wrangler JLR
I have a 23 JLR. Any way to use the transfer case in two wheel drive/low?
jludave
The Isle of Long
IT Manager
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I’m surprised none of the programmers enable 2wd low,,it would be as simple as disabling the front axle disconnect.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Where you need to make a switchback tight turn.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
Just be super light on the throttle or you'll scatter the rear axle or snap an axle shaft.
Jtphoto
Thunder Bay ON
Stopping the FAD from engaging would provide 2WD in 4Lo.
Not sure but the FAD bypass mode witt try h the Tazzer JL my do this. It would also allow you to use the rear locker in 2wd.
Zuni
Zuni
Rome, NY 13440
2023 Wrangler JLR
Out of curiosity, in what situation would you want 2WD LOW?
When trying to pull a heavy load on pavement without binding the transfer gears. More control and less wear and tear on the clutch.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Pulling heavy enough loads on pavement that you need low range...in a JL with a 2klb tow capacity....with a clutch known to explode or catch fire with no trailer? What could possibly go wrong?
Maverick909
I.E.
Backing a trailer.
love being able to use my 2 Low in my 76 gmc pickup one of the best features with a rear locker you almost never need 4wd
yokramer
Snark Incarnate
Remove the front driveshaft?
