Zuni
- Oct 31, 2022
- Rome, NY 13440
- 2023 Wrangler JLR
I have a 23 JLR. Any way to use the transfer case in two wheel drive/low?
No.Any way to use the transfer case in two wheel drive/low?
I'd need a dual shifter transfer case like the old army jeeps huh?
Backing a trailer.Out of curiosity, in what situation would you want 2WD LOW?
Uh... noJust be super light on the throttle or you'll scatter the rear axle or snap an axle shaft.
When trying to pull a heavy load on pavement without binding the transfer gears. More control and less wear and tear on the clutch.Out of curiosity, in what situation would you want 2WD LOW?
Pulling heavy enough loads on pavement that you need low range...in a JL with a 2klb tow capacity....with a clutch known to explode or catch fire with no trailer? What could possibly go wrong?When trying to pull a heavy load on pavement without binding the transfer gears. More control and less wear and tear on the clutch.
love being able to use my 2 Low in my 76 gmc pickup one of the best features with a rear locker you almost never need 4wdBacking a trailer.
