2.5 plus lifts need caster correction
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
It’s a 20% increase over what my shop told me they set and said was max
Roky
Roky
damn dude you are so knowledgeable, always appreciated your help :)
Thanks.... RK has answered a LOT of questions from me over the past 3 years, lol. I’d be interested to know why they think it’s max. Here’s an example why I don’t get it....... MC ( my second favorite lift ) on their Dual rate lift all they give you in the kit is adjustable uppers, and they have you adjust caster with stock lowers which are about a half inch shorter than yours.....?
SleepEatJeepRepeat
Newport Beach, Ca
OCMotorsports (did the install for me) set it at 4.5 and told me that was the max or it would bind.. RK told me i should be able to get 5.2-5.8 So i am taking it to another shop to have it looked over.
Roky
Roky
Sounds good....
MARSHMELLA
Kirt
FL
2021 JLUR
Military
I used some UCA correction brackets from Rancho. I got 9.5 caster with the Mopar LCAs that are only 1/4” longer than stock.
hoag4147
Colleyville, TX
2022 JLUR XR
From my lack of knowledge opinion (just reading a ton on here) based on length of LCAs mentioned by @Roky you should be close to 6 leaving the new adj uppers set at stock length.
SleepEatJeepRepeat
Newport Beach, Ca
my I am worried I will spend money to have the other shop look at it, and find out it’s really at six and he just said 4.5 when I asked ... but will see
hoag4147
Colleyville, TX
2022 JLUR XR
SleepEatJeepRepeat
Newport Beach, Ca
so just tried two different apps, cant really find one that seems to do angle in the right way.. and also not exactly sure what method to use. do i measure side of hole to side of hole, or hole to ground.. I am not very mechanical.. I am good at sports, business, and my dad game is pretty strong most of the time. :)
hoag4147
Colleyville, TX
2022 JLUR XR
I just used this app
Jeep Wrangler JL 2.5 plus lifts need caster correction 547B93BF-ADA9-4A35-AA91-93FAABA12267
and place phone on the section circled in green. It should show a percentage like in pic above.
Jeep Wrangler JL 2.5 plus lifts need caster correction B7004457-C02F-40AB-AA79-A7F209311F8D
SleepEatJeepRepeat
Newport Beach, Ca
ok so the regular iphone app level gave me a reading of zero, your app gave me a reading of 0.26..
SleepEatJeepRepeat
Newport Beach, Ca
So that would mean I am probably around 5.8 caster right? so likely the guy at the other shop was just lazy and thru out a number of 4.5 becuase he knew i had fixed lower, but didn't know that RK makes them longer, and instead of backing off when i asked more questions was prideful and talked me down.
hoag4147
Colleyville, TX
2022 JLUR XR
If zero on regular app I believe you are very close to 6. There is definitely better way to measure but that was just a suggestion to do something quick.
SleepEatJeepRepeat
Newport Beach, Ca
i will still take it to other guy, at the end of week.. but really appreciate the help.
