Heimkehr
- James
- Sep 3, 2020
- Pennsylvania
- 2021 JLU 2.0T
Pushing and holding the shift lever up, in the - M position, will put the automatic transmission in first gear. It only takes a second or two for that to occur, no matter what gear the transmission is in at the time. Pressing and releasing the shift lever will quickly change gears, up or down, seamlessly and one at a time. This functioning is plainly illustrated in the Owner's Manual, and it provides the driver with the torque delivery that he may require.the RPM range requires a device to try to mimic a manual in its shifting to get to the torque heavy RPM range - but you cant recreate that from a standstill (if youre stuck or need to climb / plow thru something)
