12V Fridge & freezer
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I had this debate with my bud, he uses the stock 12v plug in the back of his JLUR for his fridge and I use the ARB wiring kit. He thinks I am crazy and I think he is crazy. The ARB wiring kit was $21 and installed in about 20 minutes. The ARB plug screws into the ARB 12v plug so it never comes loose. That to me is worth the $21 dollars all by its self.
Blu bi Kong
Vic
Colorado Springs
2018 Rubicon JL
No debate brother
wibornz
Ted
lansing, Mi.
No debate brother
We are going on a two week camping trip from Michigan to the Rubicon Trail and Moab. I am sure during that time, he may change his mind. He has not had to use the fridge in a hot climate yet.
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
Dang! The kit cost $41 for me. I'm about to install it and am running more 10g wire for other projects. I wouldn't trust the stock plug for anything of substance.
twisty
bob
Fountain Hills, Arizona
2018 JL Rubicon White
8 ga would handle 40 amps. 6 ga would handle 50 amps. The typical cigarette lighter style power connectors are rated from 10-20 amps. 14 ga will handle 20 amps. These portable fridges draw from 2-4 amps at their maximum. Don't go overboard. And don't forget to fuse the circuit as near to the battery as practical.
https://expeditionportal.com/forum/threads/actual-fridge-power-draws.204578/
I was going to run a twin ARB off the same wire. Still might be overkill....
DanW
MILT
Milt
MN
2019 JLU Sahara
Honda technician
Tagging this thread. Awesome info. Thanks to all those providing info.
I’m planning on installing a fridge, tail gate light and 2 plug ins off the rear 12v plug. Jackery is on the list. Is there a way to use different solar panels or is it a proprietary solar input?
AdvEddie
Ed
Prescott, AZ / SF Bay Area
20 JL Rubicon EcoDiesel -15 Ram 2500 Cummins Mega
you will need adapters if you dont use jackery inputs. Some panels (RockPals) come with a set of adapters for all sorts of battery setups.
MILT
Milt
MN
2019 JLU Sahara
Honda technician
I’d like to use a military style roll up panel like a powerfilm. Those use a male 12v plug. For space consideration would like to avoid hard panels (plus soft panels are nice for backpacking)
anotheraznguy
Tracy California
Mojito JLUR
I am in the same boat right now looking for a Solar panel/blanket that folds. However my requirement is that it is unregulated since the redarc BCDC25 has a solar regulator built in.
Any insights into what 100w foldable panel would work?
RubenZ
Ruben
Deep South Texas
cyberrube.com
2018 Silverado 2500HD Duramax, 18’ Toyota 4Runner
Saw this during the Overland Expo Virtual event. May help you a bit:
RubenZ
Ruben
Deep South Texas
cyberrube.com
I'm trying to help a buddy out equipping his party bus. Do these fridges keep beer cold enough? Like 34 degrees cold? I don't know much about them. Thanks in advance
My Engel MT-45 will work as a Freezer if I wanted to. So yes. It'll keep them plenty cold.
wibornz
Ted
lansing, Mi.
My ARB will freeze your buddy's beer in Moab when the outside temp is 105 degrees.
