AA_Jeeper
Adam
Allentown, PA
2018 Jeep Wrangler JL, 2025 Jeep Grand Cherokee, 2012 Jeep Grand Cherokee WK2
Mechanical Engineer
I needed a ceiling-mount hard top lift for my garage as I don't have the available space to have it on a cart. I looked at the available options that are made for Jeep tops and wasn't pleased with them as they were either very expensive, powered (don't need powered in my opinion for the few times I use it), or have a pulley system that seemed like the lowering would be controlled enough (I need to be able to do this myself). Another requirement I had was the need to store the top with the glass closed, which ruled out the other top lifts.
My solution: I liked the crank system of this storage system that I found on Amazon (Link) as it is self-holding, and after measuring the top, it would fit nicely in the spot I have. In conjunction with the Topsy mounts (link), this solution has come together nicely. The rack allows me to attach anywhere along it's width to make sure I'm lifting straight up on the rear of the top, and a set of ratchet straps from the rack, around the bottom of the front of the top, allows me to lift this pretty well.
The crank requires about 4-6 twists per inch of lift, so I can lift and lower pretty carefully, stop to readjust, and keep going, all by myself. I've added a few pieces of pool noodles to prevent scratching, and so far I'm pretty happy with the results for under $230. In addition, I can throw the freedom tops on top of the rack and have everything stored while still being able to drive my tractor underneath to get out.
To lift the top off, I back under the rack, lower the rack until it's resting on the top (pool noodles preventing scratching), attach short straps from the rack to the topsy mounts in the rear, ratchet strap from the rack around the front of the top, take off all the top mounting bolts/wires, and crank the top up.
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 1779896881069-cc
Topsy Mounts installed:
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 PXL_20260320_000440712
Top in lifted position:
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 PXL_20260502_133211099
Top lowered:
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 PXL_20260502_163458994
Grayhound
Michigan
Jlurd
When I look at the link, I guess I have the old version with the unsafe attachment. That being said they did sent me a modification for the cable attachment. That has worked flawlessly for years now great great system don’t forget to unhook your topsy strap from under the front of the hard top before you drive out of the garage don’t ask me how I know.
Sublime
Tom
Farmington, MN
2021 HellaYella Rubicon
Looks like they've updated the Fleximounts lift. I have the old "unsafe" version but I haven't had any problems. I don't leave the top hang from it though.
Grayhound
Michigan
Jlurd
I accidentally ripped mine out of the ceiling and when I redid it I used the same frame but pulley’s and cables so as a safety back stop I installed a cable on a carabiner to catch it if my rack fails
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 imag
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
Here is what I did.
- A couple lengths of conduit rack
- 4 wall hanger hooks
- 4 eye bolts
- 4 snap rings
- 1 small electric hoist from Amazon
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0215
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0212
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0214
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0210
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0420
Warmonkey497
DJ
Michigan
2025 JL
I did one similar. Picked it up on Amazon for about $300 but went with a different 4x8 design for storage. It has a heavy-duty load limit of 650 lbs(if I remember right) and it raises and lowers with a regular drill. I picked up a bracket from Lang for the rear window since I had to mount it close to my storage rack and I won't be able to open the window while in use. I used regular ratchet straps to attach it to the lift. It works great and I can use it by myself. It really helps when backing under to put the top back on, you can push it in any direction for the final fit without damaging the top. Plus, when I'm not using it as a lift, I store all of my extra parts and junk on the rack and keep it out of the way.
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0088
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0089
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0090
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0091
Dr. RGB
Ryan
Leesport, PA
2025 JL Willys 2-Door
Professor and Shrink
Love everyon's ingenuity. Picked this up from @Quadratec, Lange Hoist-a-Top for $150 and used a wall mount for the FT's. I can leave it suspended, glass closed, no issues….
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 IMG_0398
gotbru
Nathan
STL
2024 JLU Rubicon X
Design Engineer
I used a similar kit from Amazon. Except I used the one that just had the 4 down cables. I took it a step further and put all the guts of the kit in the attic and just have the hooks hanging down in sight, along with the crank pole. My ceiling is not very tall and I wanted the top as close to the ceiling as I could get it.
I made an extension for the crank out of some scrap pipe I had laying around. I used ball joint rebuilt joints I found at a farm store for weights to hold the cable down and keep them from recoiling up to the ceiling when nothing is connected to the hook. Used electrical bushings to line the holes so it wouldn't rip the drywall.
Took a lot of time to measure everything out, but supper happy how it turned out.
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 Media (56)
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 Media (55)
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 Media (54)
Jeep Wrangler JL Ceiling Mount Top Lift - DIY-ish for ~$230 Media (51)
Grayhound
Michigan
Jlurd
Great ideas! Do you have enough cable to drop the top to the floor if you want?
gotbru
Nathan
STL
2024 JLU Rubicon X
Design Engineer
Yes, plenty. There is about 4-5 wraps of cable around the bar still when the hooks hit the ground. Actually made it a PITA to keep tension on the cables to even them up.
Wraif
Kevin
New Jersey
19 2-door manual Rubicon, 09 JKU, 23 JT Overland
That is a great job. Took a good idea and made it better. Well done, impressive. Sorry, ran out of accolades. But love your idea and execution.
