4x4tographer
Ryan
Phoenix, AZ
2018 Jeep Wrangler Rubicon
Previously, I'd asked out on the forums if anyone knew of an "overland" fridge slide solution for those of us with the soft top. The challenge (in my case) was that I want the functionality of a fridge slide without the need to unsnap the rear soft top panel every time I want to access the fridge.
Over 5 years of ownership (I'm an early adopter with a 2018), constant access into the rear of the Jeep has taken its toll on the stitching on my premium twill rear soft top panel, with tears and separations beginning to form. The fact it's held up this long with near daily "un-snappings" is a testament to the design and material quality.
My 2nd challenge was the selection of a "medium" sized fridge - A 45qt SetPower RV45 - which has proven to be a fine fridge with good capacity and great features, including dual-zone capability. This unit stands at 17.3" tall, which just clears the bottom of the soft top retention bar when sitting flat on the load floor, but leaves little room for the necessary vertical height it would sit at once on a slide platform.
With a lack of commercial solutions on the market for the soft top gang, this called for a DIY solution. I had previously built a drawer and deck system for my JL, so this was my second shot at building a custom solution for the rear. With the new fridge, I've been simply strapping it down into the rear of the Jeep on top of my previous deck and that's been just fine - until now.
Up front, here is the final result (before bed liner, paint & poly).
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform c22f79349b48ed122870823bd1265d446dd5553280749327a6
So - its time for a new building project!
Project Goals:
  • Access the fridge without the need to unbutton the top every time I want to grab a drink
  • Full extension slides that will extend the fridge out far enough to clear the top and open the lid
  • Retain a 1/2 width deck that blends into the contours of the trunk
  • Tie downs on the top of the deck for additional gear boxes, Gerry cans, etc....
  • Robust drawer that will handle the weight of my trail tools and recovery gear
  • Bedliner/sealant incase I get caught in the rain with the top off
  • A rebuild of my sleeping platform
Materials include:
  • 1/2 birch plywood from Woodworkers Source (there are a thousand benefits from working with good quality, multi-ply plywood)
  • Beadboard (used to cut as a template for mapping the Jeeps contours)
  • 500lb lock in/lock out sliders
  • Pocket screws
  • Nails
  • Wood glue
  • Kilz primer paint
  • Paint/bedliner
  • Varathane Jet Black stain
Tools used:
  • Table saw
  • Jig saw
  • Router
  • Circular saw
  • Impact Driver
  • Nail gun
  • Clamps
  • Kreg jig (pocket hole jig)
  • Mouse sander
  • Speed square
  • Contour gauge
The project started off by tearing out the old platform which was held it with only 6 bolts on the factory tie down points in the rear of the Jeep. I had a spare bit of plywood from my previous build that was already sized to 30" that fit into the rear perfectly for some "conceptualization".
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform a46acf1cbeff4c6f1a970fc324a96f3bb54ec4286d99da116b
The angle of the photo isn't great - but using a straight edge I was able to determine that the fridge would just squeak by beneath the rear soft top tailgate bar. Once you add in the additional height of a slide system and something to actually support the fridge from beneath..... there's no way it was going to work. But mounting the fridge at an angle would! We'd still need to low profile fridge slide that just barely scrapped by the floor of the deck.
A good friend of mine sent me over an awesome idea for a fridge support made of thin, but strong aluminum. He's been using a company called SendCutSend for various custom parts for a few years, and it was remarkably easy to design and build your own ideas without the need for any ultra-fancy CAD skills. If you can use a 2D design program like Adobe Illustrator - you can pretty much build anything with SendCutSend. They also have their own online design program.
The idea was to build a wooden frame around the outside of the fridge that the slides would connect to - then support the fridge with the aluminum panel. I took the idea a little further and included cut-outs for the feet of the fridge, allowing it to sit as low as absolutely possible, and included some provisions for strapping the fridge down, front and rear without the need for any hardware.
Here are a few shots of the "paper to reality" process:
The bottom of the fridge - note the riser (bumps) and the rubber feet
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 5fdfe3ac2d91d34eaf06132f07bc5bf15d4f296bb1e3c6f603
A paper template I put together based on the actual fridge dimensions. I prefer to work in metric (no, I'm not a commie!) since it's a lot more precise and much easer for my brain to do the math (I hate fractional measurements).
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 3e7d3c9de7bf00fd204187aa9f1e3fd50b6c84ca85ef6ddd74
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 951767189d55d8c7ea426580084bb1fdeaae30041d173cddb6
Here's the 3D rendering from SendCutSend of my 2D design. I used Adobe Illustrator. It allows you to note cutouts and bends.
I added in pre-drilled pilot holes around the perimeter of the panel to make installing a little easier. Note the cut-outs for the fridge straps and the feet.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 6f550b359c86a4dfc7a02d8e2eba1da210be245f0c82994e99
Here are the parts, fresh from SendCutSend. The total process was pretty simple and they do a great job of keeping you informed as to where in the process your parts are - from cutting to deburring to bending to shipping. I believe total turnaround time was 7 days for my parts.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 40a8c31c336b4186d69f25521396a3d4e6027a6fa5613073dd
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform b80d81981efec97d1a230d4657b8b7e02c783ed17dc1c32f7c
Once the parts were in, it was time to build!
First up was a simple "box frame" build with pocket holes and screws. I use Kreg products for almost all of my woodworking projects, from tables to desks to Jeep storage systems. ? All of the pockethole screws are Kreg 1/2" stainless steel.
Here's the frame, glued and screwed with the tray panel in for a quick test fit. I used the tray itself as a template to route out the holes for the tie down straps fore and aft.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform b3aea29282c8211193dfeeb5dc1474d805eeb638fa392a78f1
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 359586947ce7f9bfd20f17f753691af13d05abae2b278202ce
Used a countersink bit to help sink those #10 screws a little deeper into the tray
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 2358c286d589307c441a99081ac4e8ae6663e80a2ea51875a0
Zinc-plated t-nuts and #10 screws are used liberally throughout this project. It makes for a stronger build and is super easy to disassemble and reassemble as you work through the project. I started off with 3/4" screws, but they proved to be a little too long. 1/2" was a little too short. 5/8" proved to be juuuuuuust right.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform ae7eb45f4969e18e2cb86dde6e3fda470b4e7b8498cc4bb9c5
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 512393e615cd0958d38a00dfb0dcc472618ee650f4350883d8
Next up was to add on the slides. I measured and marked the centerline of the frame, and then bumped it up a few millimeters to allow for the frame/slide to sit as low as absolutely possible.
Again, t-nuts make this process a snap and stress free.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 2620167f179dbefff5b52a9229b58990decd4bde3c35570951
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 9427079a56853f4793ef6321173d3c2edd1b1c12ed64d644ce
I'm using Ryadon B3600 500lbs HD drawer slides. They lock in, out and at the half-way mark. They are not "take apart", so that makes them a little tricky to install. You need to push the slides forwards and backwards to access the mounting holes on both the drawer-side and mount-side. They slam latch upon close, which is a nice touch.
Stay Tuned for More...
4x4tographer
4x4tographer
Ryan
Phoenix, AZ
NEXT STEPS! Build the platform.
Loaded up the fridge, slider, and my pre-cut base plate. As mentioned earlier, the fridge would need to be mounted at an angle to clear the soft top tailgate cross-bar (no idea what the technical term for it is).
In terms of operation, the RV45 is good to operate at UP TO a 45 degree angle, which is pretty crazy. However, 45 degrees certainly isn't optimal for the system to cool properly.
I emailed SetPower's tech support folks and asked if it would be detrimental to operate the fridge at a 5-10 degree angle - they came back very quickly and said that it would work just fine, but with a footnote that it would work at its best if flat.
Stacked up some scrap boards to find that magic number to allow it to happen. This was the slowest part of the build so far and I hem-hawed on it for about 2-3 days. Using a pair of straight edges, I'd adjust the angle and place the straight edge across the top of the fridge and along the bottom of the slider to see where it would impact along the deck lip and the cross-bar.
For me, on 30" drawer slides, the magic number was 6.3 degrees with the fridge shoved all the way to the rear (front?) of the trunk area.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform ea47af104c85642393d6ba439c59b3435d3a87c8ccce3f0e70
The baseplate is bolted down to the factory tie-down points using factory hardware. I used a contour gauge to ensure the platform was cut to fit into the spot nice and flush all around, following the lines and angles of the "cutout" in the truck.
Here's a look down along the "hump" in the tailgate the houses mostly empty space, but has the mechanics for the rear door lock, handle, etc... Some considerations had to be made for how far the hump intrudes into the trunk area.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 21ad671dc32b828c35dee56f8977de5da9cc4023e2df0d4ea3
After a LOT of fussing around with it, it was time to get back to building.
Here's a jump forward to the "left wall" and "center wall" built, glued, and screwed with copious amounts of pocket screws. At the rear of the compartment I added a "cross wall" to help support both supporting walls, in addition to serving as a rest for the rear of the slide (previously, I had measured the height of the rear of the slides once I was happy with the angle they needed to be mounted at).
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform a517024a29c9776a821fddbffd0e99b69074fca91835e54497
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform b098ea360b7de1260683a1425fda85c067b391579d16db2c93
A 1/2" shim was used on the front as a "rest" for the front end of the slides. Combined, this helped ensure I stayed at 6.3 degrees and made it a lot easier to mark the mounting holes.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 4e0d6771444d37579da3a7b8c9b4bb9530d079566c46220dea
All bolted up!
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform a56dfebcee9eca0e8f1364d5bbd9de53e7f39cc785d133eed5
Verifying the slide angle in the rear of the Jeep
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform b348ab3f4cc93239c1280c412531d419ec220f54ab9cffe555
Test fitting the fridge and checking the slides:
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform b974ae44dad809189931e6e621f073447e01816e588486438d
The full-extension 30" slides allow the fridge to come completely out of the Jeep for easy loading, access, and allows the lid to open without hitting the soft top. MISSION ACCOMPLISHED!
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform cf4ef38a99e86e15955473a00c1d9396340805576097b19e2e
Back to work again, this time adding in the second "wall" for the drawer.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 99201b6e6993a2246a5fa82ba9fb9b5a56e968c678242223c6
Installing the t-nuts for the "shared wall" proved to be a little tricky. A 3/4 hole saw allowed me to countersink the t-nuts through a ply or two so they wouldn't interfere with the fridge slide. The t-nuts certainly make everything a lot easier for installing, uninstalling, reinstalling the different components of the storage system as you adjust things and take measurements.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform d599f39585e63d0acc831447956f54f2cd3dd3d65109b6d609
On my last drawer system, I had some issues with fitment with the drawers, slides, and the overall cabinet "carcass" and the fitment. This time around, I built the carcass first (as you've seen), mounted the slides, then added on the left/right sides of the drawer.
This allowed me to take some more accurate measurements of the actual fitment - which is something I didn't do on my last attempt at this. Frankly this made things a cinch and let me take measurements for the front, rear, and floor of the drawer quickly and easily. Everything fit together with no drama and the slides work as expected!
For the drawer, I decided to build the drawer itself, and fashion a "face" for the drawer that would be attached after everything was mated up and bolted down. This would allow me to adjust the drawer face independent of the drawer itself to ensure good fitment.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 30b08cb6acbd37d5a8df9869e42967a45cbf9178bee1c584cb
For the drawer face, I did a hand drawn "topographical map" design and used my ancient router to inscribe the design.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 19030aea3295dbe6044c27aac32a723f2d1fcced253f789462
For the drawer face, I'm using a jet black stain from Varathane. I'll hit it with a coat of glossy clear coat after it dries. It'l get attached last, once everything is nice and dry.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 3f605fbb8630513b4bcae1a1fd1408c2068e976146a3e28b25
Here's a test fit of the carcass/system in the back of the Jeep. I'm using some cheap, thin, bead board and a contour gauge to create a template that follows the curves of the inside of the Jeep.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 83a3e735209028c4d9c4cc85a3033188808f6a10ca285a1899
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform cac07e60ec0aa05e5cfbfebd21a8e0b1212a3603db39655fc7
Here's the cut plywood for the deck, using the bead board template. I went with a 3/4 plywood for the deck itself for a little extra strength and less "flex" for when I'm sleeping on it.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 6b424bef4f005e347dbc2f8d0361b05161a316066f2dfd7ed3
For the deck, I wanted to install some L-Track mount points with some quick disconnects. The L-Tracks I bought came with a nice rear plate that gets installed on the opposite side of the plywood for crazy strength. Normally you'd use a bolt and nut for this, but I didn't want to risk any "snag points" by using the supplied nuts/bolts. Instead, I snipped off the steel prongs on a few extra t-nuts, since they'd nice nice and flush and reduce the risk of a snag.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform ab5360d62bf87dc16f58fa62f32fde3e3813121080ec23a0dd
Here's the deck in with the L-Tracks for another test fit before I glue & screw. Note the 5/8 holes in the deck face on the right - these are access points so I can use a 12" impact bit extender to install the bolts to get the whole thing hand mounted to the Jeep's floor.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform a495ce0a2a8cee8f8b79a2ac1c231526a5cf069c032d3f6fca
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 2fa878a23a1def09deee767d0eb776521aaabe630b11951553
Here's another shot after I got the rig bolted down - with the drawer face posing for a shot:
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 4aa6cecaa167fe1ea248e62282af0d06c8fc5b1bb50565c28a
Picked up some cam buckle straps from Rhino USA for a decent price on Amazon. They're pretty good build quality and designed for strapping down dirt bikes in your truck, so I'm sure they'll hold the fridge. I ran the straps through the holes I designed into the fridge tray.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 76ff71385800d919fe266e37fcaeface3a7e6fb8eb884c728b
A few shots of everything deployed:
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 7a67ed8e77d76e7f76bcaf1f9b15eae0250b3b41be63649f13
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 68d986b167f3cdff1c3715e4fd96818272ed489ea1cf21ffb9
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 2fc8ff69bb1fcbab57061f643cad04de724f7907c94b6db1a6
Another shot with the soft top reinstalled - which is the entire point of all this!
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 47294e440f6b7e7c90f4bbde650eecc2969ca9ffc57ec13021
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform c0b45d246ad2aae206021203a103e4b086d1a2ca16d2dc48f0
In a few weeks, I'll pull it all apart and give it a coat of paint. I'm still trying to figure out what I want to do in that regard. I'm thinking of going with a satin black paint with the possibility of Raptorliner in the future. A homemade ebonizing solution of vinegar and steel wool is another possibilitiy.
My Rustoleum rattle-can bed liner held up pretty well on the last box - but I'm thinking that I might want to go with something a little nicer and thicker this go round.
Another idea could be to keep the wood "natural" and polyurethane it. Then just Raptorline the deck itself since it'll have all of the heavy duty contact.
WhatExit?
The 48th State
2020 JT Rubicon Launch Edition | 2021 F350 6.7L
Great work, project, and write-up! Thanks for sharing all the details. Love DIY projects like this!
QwikKotaTx
Houston, TX
2015 Hemi Ram, 2002 Porsche 911 Turbo
Awesome job. The attention to detail on the drawer face is amazing. Do you have any more pictures of how you attached the base to the rear tie down points? Is it simply a cap screw threaded into whatever the tie down points mount to?
AMT
Adam
Pensacola, FL
2021 JLUR 2.0T
Amazing job; fantastic detail! Love it.
On the drawer face you could paint the inside of the contour lines red to match the Jeep... ?‍♂
Never heard of SendCutSend. Very cool company.
You should sell templates.
4x4tographer
4x4tographer
Ryan
Phoenix, AZ
Thanks man!
Sure - here's a photo from my previous project. I reused the factory bolts that came with the Jeep's tie down loops in the trunk. They worked well with 3/4" plywood and my current 1/2" set-up.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 75037F.thumb.jpeg.c6ac9debb3fe4877d020c679d4b81955
The trick to getting the bolt holes drilled in the right place is to thread your bolts in about 80% of the way by hand, then lay down your board. Wack the board with a rubber mallet to leave an impression on the wood from the bolt heads and drill away.
4x4tographer
4x4tographer
Ryan
Phoenix, AZ
The last sprint on the project! Buttoning up the drawer face and building my collapsable sleeping platform.
Added a pair of cleats on the back of the box - glued and screwed. The cleats pull double duty - serving as both a lip for my sleeping platform to rest on and for the vertical supports that go under the sleeping platform.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform db57f0b93584a35d3f370931ca68e675ec49dffdf2f6d99950
Here's a photo of the cleats with the take-apart hinges installed.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 89e1fdc467691c43b6e23ccd2e37dd8d8ab47a58056e5396e7
Here's a test fit of the vertical supports. They can swing out to help dial in the stability of the main sleeping platform. Generally you'd have them out as wide as you can. The bottoms are cut to the same angle as the back of the folded rear seat for constant contact across the surface of the seat.
To install, you simply drop them into place with the take apart hinges.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 41e33f65c1089016810c9debe45320cc7380c863ffb6d13c72
Here's the finished sleeping platform - a bit of a better design than my last one. I cut out a notch to go around the center armrest. The 1/2" plywood material makes for a nice, lightweight package.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 67c81f943a55cc36469ec544c2693763fa8733dc33ebb9e377
Actually used some piano hinges this go around. Last time I only had 2 pieces, folding it in half, and used some heavy duty gate hinges that didn't allow it to fold completely flat - which was a total PITA on any trips. The piano hinges allow it to fold completely flat, and the extra bend makes it a heck of a lot more compact.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform e487e991d87523f63a4b3ef8ab581e8ab849f183636330fc49
Here's the whole contraption installed, including an additional set of take-apart hinges on the rear end of the platform to keep it locked in place while in use.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 58cddc44e027fb351fd5bc33b8e379cfadfef7bbec2ef91ebd
Here's a shot of the completed rear - with the new ebony-stained drawer face installed. I have about 5-6 coats of automotive clear coat on it - a few episodes of sanding with 220 grit made it butter-smooth to the touch and easy to wipe off with a damp rag.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform a28078472bfd2551518e292c712c87ea0bf4df96fc1d030f4a
Had a good time loading up the drawer with all my junk.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform ff8ac5afb7989a204e2c9d9796062e597d31e9da416bbff527
Tossed in my FrontRunner Wolfpack with my new high-top lid, which is my typical camping gear storage box.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform e01f59c42f950f07f353c76a7072662eb8921e5266f65deecc
The gap between the fridge and the rear of the seat has some decent space that will fix quart-sized bottles of fluids. I'm thinking I can get a full 5 quarts in there! At the moment I jammed in my ARB Tire Repair Kit which takes up entirely too much space for what is actually in the box.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 95efd343d67d631d26bed39edb6fdc4e664b262e885bd379a2
One last shot with the real soft top panels re-installed. I'm considering this project done.... until it's time for paint in a few weeks!
Oh - forgot to mention - there is space on the left of the fridge still for my torque wrench and camping table!
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform e7a659f295d6697938fe2051a9413cbd209292543be9946e73
NEXT UP - paint or stain and coating the deck surface with bed liner or Raptorliner.
UPDATE posted below.
tozalazz
aleshia
Bronco big bend
Great work! fantastic detail! expect to see the how it will look like after painting.
how did you wire the fridge to the battery?
4x4tographer
4x4tographer
Ryan
Phoenix, AZ
Thank you! Looking forward to getting it all finalized in the next few weeks.
At the moment the fridge is simply plugged in to the 12v socket in the trunk. Eventually I'd like to install an Anderson connector for a more secure connection and run a dedicated, larger gauge wire to the battery.
Alternatively, I've thought about buying an external power source, like a Bluetti or EcoFlow.
I recently came back from a 3 day trip to the bottom of the Grand Canyon and the fridge operated just fine off the main battery, but that's with daily driving.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform 7f8bc1a83dd23cbed005cb317ccc539c420735be95c4d9c3de
Wyoldguy
Derek
Wyoming
2023 JLURXR (ordered)
I’d look into monstaliner. It is tough and two part like raptorliner but come out much smoother. I used both on a teardrop build. Monstaliner was more like a basketball. The gray is monstaliner and black raptor. A little hard to tell in this picture though.
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform imag
Jeep Wrangler JL A DIY Solution for Soft Tops: Fridge Slide, Drawer System & Sleeping Platform D0FE35EE-2E08-4892-8B76-083442CFD3F3
theksmith
Kristoffer
Phoenix, AZ
2016 JKUR
congrats on having your thread featured on the homepage here
...attention whore! ;)
but srsly, nice job making things from trees while keeping all your fingers intact!
QwikKotaTx
Houston, TX
Thanks man!
Thanks for the tip, I've done that with sheet metal before.
We have the soft top and it's kind of pain to load and unload with the rear window not being easily removable. I want to build a platform that slides out but not remove the rear carpet and hopefully retain the storage well. I was thinking keep it simple and tie it in to the tie downs closest to the rear seat only and allow it to pivot upwards. I don't know if that is too much force on those tie downs though. At full extension with a bunch of gear it might be heavy create a high pull out force. Are the tie downs connected to rivet nuts in the body panel? If so, are they aluminum?
me109stock
Martin
Linden, CA
2018 JLU Rubicon 6-Speed Manual; 2008 Ford F450; 2003 Porsche Boxster S
Very nice build! :like: I did an imitation GooseGear platform w/60% seat delete, but am always dealing with things sliding around in the back. Looks like I'll be adding some sliders and compartments in the near future. Your article will greatly assist me with parts and materials, and of course the concept! DIY is always the way to go for me... I like the "originality" and the pride of having done it myself vs bought it off a shelf. And sometimes it ends up being cheaper! :CWL:
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
Great build and I love the detailed write up! Definitely something I’ll keep in mind. It is a struggle for us soft top owners for some things.
