AVGeek99
- Chris
- Aug 24, 2021
- Peyton, CO
- 2025 JLUR '41, 2024 Rubicon 4xe (wife's) Bright White
- Build Thread
- Link
Today was a long day, but it ended well, at least on paper. I got off to a bit of a late start again. My wife's been cleaning out a LOT of junk in the house so we rented a dumpster. They were coming to take that away today so I had to help finish getting rid of everything.
I got started back on the Jeep at about 11:30. In the rear end I just had the UCAs, coils, shocks, swaybar and bump stops. I figured out one pointer that's not in the instructions. You should wait to install the (rear) bump stops until after you have torqued everything down. There's no room to get a torque wrench on the UCA at the axel when the bump stops are installed. Like when I was working on the YETI, the only thing that gave me any sort of trouble in the rear end was getting the bolt started on the nut on the passenger UCA at the frame. Here's a shot of the rear end before I put the tires back on.
With the rear tires back on and off the jack stands I measured the drive shaft and pinion angles to see if I needed to adjust the contol arms. Thankfully they were within .4 degrees so I called it good, at least for now. All that was left in the rear was torquing everything down and insalling the the bump stops.
I then moved back to the front to check the castor. Unfortunately that wasn't so good. The MC instructions provide starting point lengths for the contol arms that target 6 degrees of caster. Since my lift is 3.5" and I have no FAD I wanted to get more in the 4 degree range for caster. So I thought I would be smart and come up with my own lengths. BIG mistake.
I didn't get a before picture, but when I measured the caster in front, my angle finder read 84.1 degrees, which equates to .1 degrees of caster. I wasn't even going test drive at that caster. I'm sure it would have been a shit show.
Normally you can make caster adjustments with the Jeep sitting on the ground. Mine was so out of wack I had to put it back on the jack stands to make the adjustment. I ended up setting all the front CAs at MCs recommended length. I figured that would get me close enough that I could then make final adjustments with the Jeep on all 4 wheels. When I got it back on the ground I meaured and got a reading of 88.1 degrees, or 4.1 degrees of caster, .1 degrees more than I was shooting for in the first place. I celebrated a bit when I saw that reading.
Since I had both front wheels off again I checked the toe, perfect. This didn't surprize me too much, since my SS Yeti TR came off the YETI and it had a good alignement. Then I got the front tires back on my wife got in to help me adjust the DL to get the steering wheel situated correctly.
With the late start I called it a night. Tomorrow all that remains before the test drive is to torque everything down. I'm hoping with no FAD that 4 degrees of caster will be little enough to mitigate any DS vibrations.
Here's how Yoda is looking now. Just like when I got the YETI back when it was lifted, the 315/70s look almost cartoonishly small. In desparate need of getting the 37s swapped over to Yoda.
