Wrangler JL Hood Locks
Waynev01
Wayne
2020 jeep wrangler jl Sahara unlimited
Hi, I recently joined the "Jeep " life.
I purchased a 2020 Sahara unlimited. I was curious on thoughts of hood locks. I've seen some that are steel and some I'm guessing are ABS maybe ? What do all recommend ?
OminousSkitter
The Ether
Trek Bicycle
The Bolt option is well regarded. That's what I installed on my Jeep.
Note that you'll need a rivet gun capable of handling the provided 1/4" rivets.
The rivets aren’t required. I did it with some spare nuts and bolts, but rivets would be easier/more secure.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I did the bolt lock and replaced my hood latches with locking latches. I also relocated the horn wires so they can’t be cut or seen from the grill. Then I used JScan to make the hood sensor link to the car alarm. So if the hood does open the alarm will sound
Boatbuilder88
New Jersey
'19 Wrangler JL
F-16 Engineer (retired)
My wife and I are retired and we take a lot of road trips in our Jeep. We don't want to be stranded somewhere with a disabled Jeep or no Jeep. Insurance doesn't help much when stranded.
Like @ScotM, I have a multi-faceted approach to engine bay security. I have locking hood latches (visual deterrent but not too secure), the Taser hood alarm (audio alert), and the Lasfit Stealth Hood Lock (physical lock).
FWIW... After using it for a couple of years, I can honestly say that the Lasfit hood lock is a great product. It works with the Jeep's key fob and the grille remains stock.
Also, @Lasfit customer service is top shelf! I had an issue with the hood lock's manual pull cord. Customer Service was very responsive, helpful, and patient. Problem solved!
Hey Jeep, it's 2025! The Wrangler needs a locking hood and fuel filler door!
ScotM
Scot
Southern California
FWIW... After using it for a couple of years, I can honestly say that the Lasfit hood lock is a great product. It works with the Jeep's key fob and and the grille remains stock.
I bought the locking gas cap off Amazon and keyed it to my fob.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
The locks that hold the hood down do not work. I installed a pair and forgot to give the mechanic the key and he simply pulled the latch down and opened my hood. I had to bend back the metal to make it work again. you are better off with the Bolt hood lock.
JINO
Jino
Socal
2021 jlurd
Has anyone used the jeep kill code using tazer?
Theft is common, and i have tazer, wondering if I could use that to any benefit.
Or would hood lock be better? As i do use remote start nearly everytime I start my jeep.
