Dyolfknip74
- Mar 18, 2021
- Ottawa, Ontario, Canada
- 2021 JLU Rubicon
Winches have been installed for years without a seperate solenoid. I wouldn't expect a delaership to even know they exist. Calling it negligence is a little heavy handed.At first blush from the cheap seats in the spectator gallery, the charges do appear a bit excessive and without further inquiry it is somewhat difficult to ascertain their validity. However, regardless as to the propriety of these charges, you should immediately take the Jeep back to the dealer and ask them where the WARN Power Interrupt Kit is installed and ask how it is switched. No reputable service shop should install a winch (or any other power driven device) without considering a power disconnect mechanism, particularly given that it appears they are making the repairs only because they discovered a frayed wire, strongly suggesting it could happen again. By wiring the winch directly to the battery, they have provided no way to automatically or otherwise kill the power in case the positive lead shorts against a ground in the future, perhaps inadvertently or from your involvement in a crash. Can we say fire?
The Power Interrupt Kit provides a system that routes the positive lead from the battery to a solenoid (and then from there a “positive“ cable runs to the winch) which is then controlled by a switch (wherever you choose to mount it; mine is on a dash-mounted switch panel) preventing power from being present at the winch except when switched on for actual use. At all other times, there is no power present at the winch. Sorry folks, but no one should ever consider mounting anything involving power that is not fused or otherwise protected against a short. This kit does that. Failure to do this in your driveway is called whatever you want to call it; failure to do this at the dealership is called negligence.
For what they charged you, and for safety’s sake, I would strongly suggest a return to the dealership.
