winter gasoline = increased fuel consumption
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
For more than a month I was away and now that I got back to driving my 3.6 JL I noticed about 10% higher fuel consumption. Most of us are well aware of the fact that in the cold winter months the engines will suck up more fuel but the weather so far has been pretty mild here in Ontario and I just noticed today the computer indicated 13 liters/100 km [ 18 mpg] .I used to be around 20 mpg. I suspect the winter gas mixture may have something to do with it.
cb4017
Cliff
Northern Nevada
2025 Gladiator Mojave
I notice the same thing with the winter gas blends.
spurly
Zach
Nebraska
2019 Bright White JLUR
Winter gas has everything to do with it. Winter gas has somewhere in the range of 2-5% less energy than summer gas
Mikeoso
Iowa
www.iowaparrotrescue.org
Ram 1500, Jeep
Retired history teacher
My MPG is down by about 5%
RV Wrench
Paul
West Richland, WA
84 Cherokee, 93 Wrangler, 19 Wrangler
Your engine runs in open loop mode until it reaches operating temp, then it runs in closed loop mode and is more efficient.
I had a minivan once that averaged 22-23mpg overall. That average plummeted to 18 when the thermostat stuck open and wouldnt let the engine reach operating temp.
You are loosing fuel mileage due to longer warm-up time and more idling/warmup time.
I dont think there is any difference between winter and summer GASOLINE. Diesel, yes, but not gasoline. They have no reason to change the gasoline formulation, it doesnt gel like diesel.
Litfuse
Columbia, IL
2019 C7 Grand Sport, 2019 Ram 1500, 2017 Audi Q5.
Depending on your location, there is absolutely a difference in summer and winter blends.
Litfuse
Columbia, IL
It's known that the winter gasoline is cheaper.
I was told it has to do with flash point.
In summer, they have to produce higher quality fuel so that the flash point is also higher in order for it to be stable during months where the temperature is higher.
But come winter, that obligation is lifted and you get the cheap stuff.
The detergent package is the main difference between the two blends.
daveprice7
Junction City, OR
2020 Willys 2DR, 2024 Gladiator NightHawk
Nerd
I noticed in the last few weeks my engine (v6) was sputtering occasionally when I was cruising at low RPMs (1700 ish), I.e 60mph in 5th gear. I've had to change to cruising at lower gears, effectively turning my 6-speed into a 4-speed. Strangely, my fuel economy hasn't been hot too hard; less than 1 MPG.
amnesiac
Cleveland
2020 Wrangler Sport S
I’ve never heard of “winter gas” before.
can someone please explain this concept? why is this a thing?
cosine
NY
2019 Wrangler Sport jl
Gone Postal
i've noticed a 1-2 mpg drop.since the colder weather showed up.
