winch wiring question
MyDaughters20JL
WA
20 JL Sport S
if I disconnect both the battery terminals on my battery, is the aux. battery still going to be connected? jsut want to make sure I don't fry my electrical system when hooking up my winch
jludave
The Isle of Long
IT Manager
You need to disconnect and separate the 2 wires on the negative side.
MyDaughters20JL
MyDaughters20JL
WA
20 JL Sport S
My plans were just to disconnect the terminals from the upper battery. I was just wondering if that was going to disconnect the auxiliary battery as well
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
No.
Do as @jludave said and separate the wires on the negative side as well.
jludave
The Isle of Long
IT Manager
No. Disconnect and separate the 2 negative battery cables. Keep them separate so that they don't touch.
You don't necessarily have to disconnect the positive side, but do it just to be 100% safe.
MyDaughters20JL
MyDaughters20JL
WA
20 JL Sport S
Perfect!
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Why are you disconnecting the battery to hook up the winch?
jludave
The Isle of Long
IT Manager
Safety measure.
You should always disconnect the battery doing any type of electrical work.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Safety measure.
I understand that but all you’re doing by installing a winch is adding two cables to the existing battery terminals.
It makes no sense to disconnect existing cables only to add two cables and reconnect everything
jludave
The Isle of Long
IT Manager
True. But if the wires being added/connected touch somehow, or the installer's tool touches something else that's metal, or there's a short in the winch, etc...
These things can happen.
These vehicles are very sensitive to anything electrical.
