Winch install: Project Overkill
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
Sorry to make this thread in Blog fashion, but it's how I think, in not being distracted by too many questions at once. I placed details 1st as I go. Until I complete my Install then you will see how things are installed and function.
1st the basics.... I have two variants but only using one on this thread. It is the simplest to setup and requires no physical alterations to make the system work. All utilize a smart battery control module and heavy duty contactor / solenoid. Once everything is setup, you will have a fully protected cabling, charging system and battery, from winch malfunction, from various issues. A compromised winch power cable, crossed connections or shorted out motor.
Many will say what I am doing is not needed. Thus my thread heading Project Overkill.
This is my circuit that I will install...
Jeep Wrangler JL Winch install: Project Overkill 1000039415
I included an optional override switch in case the XY-CD63 should fail.
YBABRAT
VIRGINIA
1st item the solenoid....
Jeep Wrangler JL Winch install: Project Overkill 1000039468
Yes it is over kill but being surplus old stock and made in the USA, with silver internal contacts instead of copper... I could not pass it up. There are others out there, yet I like thus style, due to the isolation between contacts. This ohmed out to a little over 8 ohms. Current is a wee bit over 2A. Very powerful on its throw. Unfortunately I will not be testing it's design effectiveness. Meaning it is not intended to switch on a live connection like a light switch. There are differences between closed contacts in a live circuit vs an open circuit. Live will provide the greatest chances of voltage arc at contact points. Contacts are not 100% effective until full closure. That is why this solenoid is used as a power enable before winch is activated.
You could probably scout a U-Pull-It and get a F250 Super Duty starter solenoid and do the same.
YBABRAT
VIRGINIA
2nd... The brains of the system.
Jeep Wrangler JL Winch install: Project Overkill 1000039469
I chose to show the XY-CD63 with a common light switch cover. Being plastic, one can cut, heat mold or even graft plastic material using plastic weld epoxy. I made an adapter plate that is hidden behind the light switch plate. I may obtain a stamped metal sheet switch cover and work with that as to trim down size. Another option is to remove the plastic housing and mount flush to the switch cover. It's all dependant on your own capabilities and creativity.
YBABRAT
VIRGINIA
If you're using an on/off switch what is the purpose of the solenoid?
No, just gave an option if the XY-CD63 fails. The circuit sort of shows where to jumper if no optional switch is used.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Mine came with a switch so I installed it. My previous winch (Badland) didn't come with one, never a problem but I've read in case the winch shorts out it's good to have so it doesn't drain the battery. Easy enough.
Jeep Wrangler JL Winch install: Project Overkill rec2
Flip
Johnny
Virginia
A marine fuse was also recommended. I thought that was a good idea.
YBABRAT
VIRGINIA
I was going to post the instruction sheet to the XY-CD63, but it is translated from Chinese. It's done OK, but can confuse some on operation. I will have to make an entry on the XY-CD63 setup. Once you go through the functions, the adjustment and operation will be fairly easy to remember. At the time of testing, I never bothered about making an instruction. There is a few videos from an English chap, but his videos can be... let's say I did better on my own.
YBABRAT
VIRGINIA
This idea was for simple operation and millisecond response to protect from an unknown catastrophic issue. They are rare but as long as a charging system and battery are used together to provide maximum power to winch, your battery and charging system can be compromised. My circuit protects before damage can be done... if setup within safe limits.
YBABRAT
VIRGINIA
Understood with simplicity. Though I removed the need for manual interaction under hood.
Deleted User 38384
I'm going to drill another hole in my hood this weekend and install an on off switch on the exterior of the Jeep.. it'll be the school heavy duty manual metal switch sitting on top of my hood. It should look pretty ridiculous, but it'll be functional‼
It's marine grade so it should hold up fine! :CWL: :handsinair: 🤷‍♂️ ;)
YBABRAT
VIRGINIA
So far the Orange and Pink wire is for Aux 3... partially installed the XY-CD63 battery controller to my console, right under the aux switches.
Jeep Wrangler JL Winch install: Project Overkill 1000039482
A little trimming and a few additional panels to cover open areas for fitment. Once fitting is done, a covering of fiberglass and final shaping before paint.
Tested function having shifter in park... no issues adjusting buttons.
Set aux 3 to function when ignition is on and reset when ignition is off. When Aux 3 is active the XY-CD63 is on and ready to winch, as long as voltage is set. You will need to adjust battery voltage depending on temprature and charging system operation.
The read out Is live readings.... all the Jeep features are delayed by CAN bus and ECU driving the charging parameters. ECU will show random pulses of voltage, but actual voltage at battery will be more steady.
Jeep Wrangler JL Winch install: Project Overkill 1000039483
Jeep Wrangler JL Winch install: Project Overkill 1000039480
Jeep Wrangler JL Winch install: Project Overkill 1000039479
Jeep Wrangler JL Winch install: Project Overkill 1000039481
Flip
Johnny
Virginia
Nice job, I thought it was stock at first glance.
YBABRAT
VIRGINIA
Solenoid install... very tight with this mofo. Have to flip it upside down and use a bracket to mount to the fender frame. Luckily there is ground studs near by for the ground terminal.
No obstruction nor open contacts to short the solenoid terminals.
Jeep Wrangler JL Winch install: Project Overkill 1000039484
After thinking about cabling... it may be worth moving cables for different battery case styles.
