Winch Install on. 3.6 E-Torque?
BruceyZ06
Bruce
Albuquerque, NM
2020 Jeep Gladiator Rubicon
I feel dumb for asking this. Recent acquired another Jeep. 2022 Rubicon Extreme Recon 4 Door w/ the 3.6 V6 with E-Assist. I'm installing my winch on it soon. I can kist install the battery cables to thew 12 volt battery correct? Or am I wrong? Thanks!
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Yep. 3.6L eTorque here. Hard wired my winch to my 12V battery. Simple.
Roky
Roky
I have an on/off switch on my winch, so I wired to aux switch to reduce any shenanigans…….. the aux switch doesn’t turn it on it just turns on the power to the winch……
https://www.jlwranglerforums.com/forum/posts/1330500/
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
My winch came with a on/off switch, this was new to me. I made a bracket and mounted the switch. I figured why not.
Jeep Wrangler JL Winch Install on. 3.6 E-Torque? IMG_bracket
Jeep Wrangler JL Winch Install on. 3.6 E-Torque? IMG_bracket1
Jeep Wrangler JL Winch Install on. 3.6 E-Torque? IMG_switch
shooting4625
Colin
Coming soon 2023 2door wrangler Rubicon
I installed a warn relay on a bracket I made as well and a fuse relay box for my lights, I have the winch turned on by Aux switch 4, I don't like to lift my hood unless really necessary.
Jeep Wrangler JL Winch Install on. 3.6 E-Torque? 123
dragoneggs
Seabeck, WA
Iā€˜m the opposite. I open my hood often to check fluid levels, any leaks, or loose connections, and will wipe down dust and use air to flush out debri that has found its way into cracks and corners. I just like to inspect and check things out regularly.
Recon23
San Diego
2023 Wrangler Rubicon Recon
Hey guys, I also have the 3.6 with e-torque. I thought I read somewhere that when wiring to the battery that we should run positive to positive on battery, but in the case of negative run to one of the grounding lugs on the fender by battery? I believe it has something to do with that little connector at the negative battery terminal could be damaged by the draw of a winch or compressor. Can anyone confirm this is true or an incorrect assumption? Thanks
