Whistlin' Dicksie
Terrymo
Terry
2023 JLURXR 3.6 ET
Here’s a post from @The Last Cowboy. Not sure if it’s related.
It will likely be the small trim piece at the bottom front corner of the window, next to the rearview mirror. I popped it off, taped over the holes under it with quality duct tape, then put just a slice in the tape for the alignment pins and clips to go though. Then I put 3M automotive molding tape around the edges of the trim pieces before putting it back on. The wind noise was very significantly reduced after that.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
My fix was more for the wind noise, which would get bad on the highway. Those little filler pieces at the front lower corners of the door windows are the problem. Whistling is different, and suggests air rapidly moving over a sharp edge.
My antenna sometimes whistled before I covered it with electrical shrink wrap. But it only whistled when I was in a crosswind, driving on the highway.
Brad Hearing
Brad Hearing
Alberta Canada
2024 Sahara V6 auto
neat. yeah im thinking it might be related to the third party windshield i had installed as well. it seems to be coming from right there the rear view mirror is thanks for that
Brad Hearing
Brad Hearing
Alberta Canada
2024 Sahara V6 auto
Anything on the exterior of the Jeep is a candidate.
You need to have one person track it down while someone else drives.
the pisser to it all is that its intermittent. was fine this morning when i went out. yesterday it screamed all the way into town. its gotta be that a door just isnt closing right or perhaps the sudden air pressure shift from the door close itself pushes back some rubber or something i dont know.
Had the wife ride like we were muslims so she could try to find it while we drive. maddening because I hear it behind me while shes convinced the sound is coming from the top center above the rear view mirror. shuffling around with a towel to try to block areas at random hasn't yielded results yet.
Its the perfect annoyance - there is no point in taking it back to the dealership on this one yet the jeep is new.
Wbino
NJ
Racist much?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Sounds like the office pranks we used to pull in the old days. Get a device that beeps randomly at a frequency that's hard to track down and put it in the ceiling of an officemate.
Brad Hearing
Brad Hearing
Alberta Canada
2024 Sahara V6 auto
Racist much?
you mean religion. if it was racist i would have said arab. you get offended pretty easily hey?
its literally how traditional muslims drive *and* walk in public.
Brad Hearing
Brad Hearing
Alberta Canada
2024 Sahara V6 auto
yeah i thought about that but i keep it in a garage and dont have friends that would do such a thing even if they had access to it. it sounds like a natural thing.
my guess so far is the stripping on the roof panels arent sitting right. next time it acts up ill shuffle those around and see what happens
Wbino
NJ
Keep digging.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
Just crank up the music 😇
