AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
That's what I though I did when I tagged @flanders, I presume the same one from the JT board, maybe not.Why don't you take your questions back to where you got them. IIRC, Shadowpapa is one of the members who has identified the actions cause by identical voltages for 6 straight shutoffs.
I don't see benefit in rhetorically asking the people you reference, who (I think) you claim themselves saying ESS turns off from 6 identical voltages, "what factor it is (i.e. these identical voltages) that causes this shutdown" or why Stellantis chose "6" as their metric.
I do see benefit in understanding, if the batteries are in parallel in ESS events as @flanders claims (as is his right), which means their voltages are likely to stay very close, why ESS doesn't shut off after 6 ESS cycles.
Does it? Is this 6 ESS cycle claim not true? Is there some other factor that's causing this 6 cycle shutdown other than similar voltages in the two batteries? Do @flanders observations not apply to the entire 3.6L/2.0L dual AGM JL/JT power plant across model years?
I don't belong to the JT board (I think). Maybe I should join.
