When to cool engine
Bob D.
Bob
Massachusetts
Jeep Wrangler Sahara 4xe
My wife and I will be off-road for 3 days late this month in Canyonlands National Park and I'm wondering if there is an engine coolant temperature, transmission temperature, or engine oil temperature at which you would stop driving and let the engine cool down. The two vehicles are '24 Rubicon's with the 3.6L V6 and it's easy to monitor the aforementioned temperatures on the dash. I take it that 220 is a normal temperature while 240 is overheating. Would you give it a rest at 230? Being from Massachusetts I'm not familiar with driving in desert heat. Thanks.
  • Like
Reactions: ARY
azjl#3
North AZ
If you have the AC on the fan is on and you should not really see much over 220. I have found a way to force hi fan is to set temp to full cold, and the fan comes on hi/higher/
Oil temp, is based on RPM so if you are using 3,000 plus it can creep up, but should not go over 240.
I would just slow down if you see water/coolant over 220 and oil over 230.
If you really hit the limits the computer will pull power and set you into limp mode.
Dads from Quincy, say hi, get a dunkin!!
WontonJLUR
Suffolk, VA
2019 JLU Rubicon
I wheel the piss out of my Jeep in the south, in the summer, for multiple days straight. The fan will get loud and howl but you’ll be fine.
jadmt
jeff
montana
I have been to Moab in june and july several times where ambient temps were over a 100°F and never had an issue with temps getting too hot. we are talking all day trail runs.
Reinen
2021 Jeep Wrangler JL Rubicon
What can bite you in that area is wheeling hard, shutting off the engine for 15 minutes or so, and going back to wheeling hard. The engine compartment can get a serious heat soak. One time my Jeep went into limp mode and thought the outside temperature was 156F after I did that. Even the windshield washer fluid tank was too hot to touch. The solution is to pop the hood and let the heat escape.
But outside of that, as long as your coolant level is full and your radiator is clean (no dirt/bugs/etc clogging it up) and your engine is running, you'll be fine. Expect the fan to go into "turbo jet" mode occasionally, it's normal.
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
240F isn't overheating.
Terrymo
Terry
2023 JLURXR 3.6 ET
If you are not actually overheating but get concerned and don’t have a Tazer to command 100% fan speed you can turn your A/C on high and set to floor vents only.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Or just let it idle if you're only stopping for a few minutes.
azjl#3
North AZ
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
In my book, it is too hot. High temps reduce emissions, that's why manufacturers do it. Same with the thin oil, which improves CAFE. Both can be hazardous to engines over time. I did 3 things: Mishimoto radiator, 185° thermostat, RPM Extreme fan controller. I have never seen a temp over 197°, and the temp usually is around 188°. Also using Redline 5w-20, one of the TRUE synthetic oils.
Kracka
Christopher
Oak Point, TX
Everyone is free to believe what they wish.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
You may chose to run your jeep at 240 degrees. NOT ME.
  • Normal Operating Range: 195°F to 230°F (90°C to 110°C) depending on the load, towing, or ambient outside temperature.
  • Warning Sign: At 240°F (115°C), the cooling fans will run at maximum speed and the computer may start pulling engine power.
  • Limp Mode: At 250°F (121°C), the dashboard will illuminate the red warning light, and limp mode will activate.
shane h.
Shane
DFW
'19 Mojito JLUR (mine), '21 Hellayella JLUR (hers)
Husband, Father, Papa
RPM Extreme fan controller and forget about it. Or get that guy that is tuning 3.6s (if yours is a 3.6) to tune it. I think his tuning includes new fan parameters.
I have run RPM Extreme fan controllers in both of our JLURs for 13 months now. Zero issues. Once up to operating temps, I have yet to see coolant temps above 207. Usually runs around 197 in summer unless I'm really pushing it. Oil temp will usually run 8 to 10 degrees warmer.
We did all of the White Rim Trail at Canyonlands last fall in a single go. Never had issues with high coolant/transmission/oil temps. We make annual trips up to the San Juans to Jeep. Before the fan controllers I always saw what to me were very high coolant/oil temps. Two trips now with the fan controllers and I never see the spikes.
Nokones
Kenny
Sun City West, AZ
