21_Sarge_JLUR
- Matt
- Mar 27, 2021
- Baltimore County, Maryland
- 2021 Wrangler Unlimited Rubicon - 6 Spd
295/70/18 Mickey Thompson Baja Boss A/T’s and 1” Bora hubcentric wheel spacers.
DadJokes, that looks fantastic! Any issues with the OE wheel studs being too long for the OE wheel pockets using those 1" wheel spacers from Bora?295/70/18 Mickey Thompson Baja Boss A/T’s and 1” Bora hubcentric wheel spacers.
The 17’s were just a bit wide for my liking by the time you were pushing 35 inches tall.
The factory studs only protrude .410” past the 1” spacer. There’s up to .750 pocket depth on my Rubicon Upgrade wheels (not installed) and these Sahara upgrade wheels appear just as deep so there’s no interference fitment issue with a 1” spacer.DadJokes, that looks fantastic! Any issues with the OE wheel studs being too long for the OE wheel pockets using those 1" wheel spacers from Bora?
What spacers did you use. Anything under 1.5 is a different bolt thread for the Jl. I need it to be M14 all around. I read all 5 pages but can you tell me the exact model number that uses the M14 stud? ThanksThe factory studs only protrude .410” past the 1” spacer. There’s up to .750 pocket depth on my Rubicon Upgrade wheels (not installed) and these Sahara upgrade wheels appear just as deep so there’s no interference fitment issue with a 1” spacer.
In effect, since the Rubicon axles are .750” longer per side, this sticks out only .250” further than the same tire fitted on a Rubicon. These are Rubicon fenders in the pictures.
And if you don’t like the commonly brightly colored spacers, these Bora spacers are black.
Post 58 & 60. Still the stock studs.What spacers did you use. Anything under 1.5 is a different bolt thread for the Jl. I need it to be M14 all around. I read all 5 pages but can you tell me the exact model number that uses the M14 stud? Thanks
Thanks! Got them ordered. Expensive suckers.Post 58 & 60. Still the stock studs.
Just wanted to say thanks for the good info in this thread.Post 58 & 60. Still the stock studs.
