GrayWolf.Overland
- Subash
- Sep 9, 2021
- Maple Ridge, BC, Canada
- Website
- www.instagram.com
- 2025 JLU Rubicon (Anvil Gray)
- Build Thread
- Link
- Vehicle Showcase
- 2
Lift manufacturer recommendations are based on lowest common denominator..in the case of JL that guidance is for sport all the way to Rubicon. Since you have wide track axles you are already 3/4" wider at each end than sport..so factor that into your backspace.
IMHO you shouldn't need any spacer period.
If you have to run when spacers, use only a hub centric bolt on spacer. The ones that just slip between adding 1/2" etc are not a good idea for offroad vehicles.
If your wheels have groves/pockets behind the hub next to the lug holes (like how stock wheels have), you can get away with a 1.25" hub centric bolt on spacer.. Mammoth offroad at extreme terrain has one.
