Wheel Spacer Questions
CMTAZ
Phoenix
2024 JLURX Anvil
So, nilight sent me a set of their wheel spacers. Initial thought is they are nice, good finish. Not sure if I want to use them though .
The directions call for torquing the spacers to the wheel @ 30 lbs. Seems odd to me as wheels are usually torqued @ 90 - 100 +/-. The directions call for torquing the wheels @ 85 / 90 lbs. No mention of loctite, I've heard some spacers recommend using blue loctite.
I should mention that I do moderate wheeling, but the spacers would primarily be for appearance.
Thoughts and opinions?
https://www.amazon.com/Nilight-2011...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
JPXR
Tim
Columbus Ohio
’22 JLUW XR 2.0T, ‘23 JLU 4xe Sahara
IT
I would go with red locktite and 130lbs.
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
https://www.amazon.com/Nilight-2011-2022-2018-2022-2019-2022-Gladiator/dp/B0D25QC3XT/ref=sr_1_1_sspa?crid=3RBFZC4U8AEF2&dib=eyJ2IjoiMSJ9.q_fnNn0EU96KfBhk48V2psXzDjvN71ktRDY_JaliE7uq-kPYz7SLk3sB8prFAgLcOZEHfZ5ztWEtnmsXlvydz4h8GTHzb2eOne4l7Q4B70EKm_bm3az_LloQ0ivKr8DR9RBYwVKOGSahEZ0-MPi_D-nWZsf8NRDJPlHaEbiGi2oj0kLUAa9fDEQlPgYqaV4srVOtt2-RDQiNJblmYO4l4b92qmpkoAwDSFQEjrTjiO0.h_3YQeLF-3S2xhIQqA8f_8awo6WcHxfzcmQ16olO4wI&dib_tag=se&keywords=nilight+wheel+spacers&qid=1722300556&sprefix=Nilight+wheel,aps,185&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
I personally would not use an “Amazon” import brand for something this critical. Nothing against spacers, I ran Bora spacers without issue and wouldn’t hesitate to put them back on if I ever switch back to my original wheels. I suspect my opinion will be in the majority. Good luck either way. Be safe!
jadmt
jeff
montana
BORA which is top notch says torq to factory specs which are 130 ft/lbs. they do say not to use locktite. I have checked mine 3X since installing and they have not ever taken even a spidgeon of torq. I would not trust Nilight nope nadda...
CMTAZ
CMTAZ
Phoenix
2024 JLURX Anvil
BORA which is top notch says torq to factory specs which are 130 ft/lbs. they do say not to use locktite..... I would not trust Nilight nope nadda...
Spidertrax says torque to 130 ft/lbs also, but they recommend blue loctite. After using several Nilight wiring harnesses (foglights), I was impressed with them,
BUT !!!
after looking at BORA & Spidertrax and the cost difference,
I'm not taking a chance on a part that is this critical.
If I was guessing I'd guess the Chinese documentation was wrong, they meant 130 ft/lbs and printed 30 ft/lbs. But I am not a metallurgist, and not willing to risk the jeep, my passengers, or myself.
Thanks all...
Blckdog
Kevin
Connecticut
2023 Willys JLU
Just ordered a set of Bora’s 1.75” spacers from Motorsport Tech. They called to confirm the order a said there was no need to use Loctite. Torque to 130ft/lbs and you’re good.
Will still retorque them after 100 miles or so to make sure.
