Wheel Spacer size
ShawnWhite78
Shawn
Ontario Canada
2021 wrangler high altitude
Hey everyone just bought a 2021 high altitude and picking it up Thursday and want too order some stuff and need some info. I want too run 35x12.5x20 on factory wheels and need too know what size spacer I need (don't want too cut the studs either)too accommodate this with a 2.5 rc Lift. Thanks for all the help.
Cheers!
gato
New England
2021 JLUR
If you are running the factory wheels, they have pockets on the back face that enable spacer studs to fit, even if they protrude from the spacers.
So, you should get the narrowest spacer you can find which is 1.5" for the JL application.
E.g. https://www.quadratec.com/p/crown-automotive/1.5-inch-wheel-spacers-wrangler-jl-gladiator-jt
This will keep your tires as much as possible under the fender flares (to be close to road legal and prevent mud/rocks from being flingged at the sides of the Jeep.
And will also keep your scrub radius as close to stock as possible, while minimizing the extra load in the suspension steering components.
ShawnWhite78
Shawn
Ontario Canada
Thanks for the info, as far as a spare tire carrier for a 35 i assume I'll need a brace if some sort?
