What to do after Wrangler rollover?
sk89
Shamseer
Qatar
Wrangler Sport
Hello dears,
please advice me regarding
1. My JL wrangler 2020 rollover in desert 4 times, after that, what are the precautions I need to take care
2. Can I drive the car since there are no indications are shown in instrument cluster
3. As of now only body damages are found
4. How I can make sure that no more mechanical issues in car (no unusual indication in cluster)
5. Some oil over flaws happened
need help to survive my wrangler from this incident
Jeep Wrangler JL What to do after Wrangler rollover? C737B782-5D88-4C06-97C1-1B84022FB646
am1978
MD
2018 JLU Sahara Bright White, 2018 JLU Sahara HellaYella
ā€˜Merica
Following. Interesting.
631_Islander
Area Code 631, NY
2020 Unlimited Rubicon with 8 speed and 3.6L Pentastar without eTorque.
Business Development Manager for the US arm of major global Fortune 500 Japanese Electronic Components manufacturer headquartered in Osaka, Japan.
Hello dears,
Please post pictures. Most important: check alignment and see if ok to drive. If
ok to drive: take to your mechanic or dealer. Not recommended to drive yourself but if you are in middle of desert with no way for tow truck to come, you may have no choice.
If not ok to drive or you see too much oil: tow to your mechanic or dealer. When towing: DO NOT FLAT TOW and ask tow truck driver to bring flat bed.
limeade
Guy
Reno, NV
Hello dears,
If your Jeep was resting on it's side or upside down for anything longer than a few minutes, some oil could have seeped into the upper cylinder (above the piston). If this has happened and you start the engine, you risk hydrolocking your engine. The result wil be a bent valve, connecting rod, etc. which will necessitate a rebuild at minimum.
To get any oil out of the upper cylinder(s), you'll need to remove each spark plug individually and then turn the engine over (without starting it.....which should be obvious) to ensure there's no oil in the upper cylinders. Have someone watch each spark plug hole to see if any oil is coming out (you can have them hold a white towel, napkin, etc. lightly over the hole and any oil will show up on it). Continue to bump engine over until no more oil is blown out. Re-install spark plug and then move on to the next cylinder. Continue with each cylinder until your are 100% positive all oil has been removed from the upper cylinders.
If you take all the spark plugs out at once, there might not be enough pressure in all of the cylinders to blow the oil out.
I'd recheck your oil level afterwards to ensure you didn't lose too much so you can drive home.
I've rolled a Jeep before and did this same procedure. Never had any engine issues.
SilverSurfer
Heinrich
South Africa
2020 JL Rubicon 3.6 8-speed Auto
Rather do not drive it, you have lots of checking to do.
Fluid levels (Oils, Radiator fluid)
Radiator damage
Alignment
Bent chassis cross members/ broken mountings (Engine/TC/Gbox)
Electronics (Error codes is a good start).
Structural check (Welding points torn)
Prop shaft angles
Bent axles
Depending what exactly happened the list can get longer.
631_Islander
Area Code 631, NY
You rolled it 4 times? All I can say is Wow...
He rolled over 4 times, survived it without injury and it seems his JL is still running. Tell me any other brand out there that can take abuse like this and allow a driver to walk away without major injuries. Go ahead NHTSA. I am waiting! In other words: eff your safety ratings telling that the JL is not as safe
631_Islander
Area Code 631, NY
Radiator damage
Alignment
Prop shaft angles
Bent axles
Unfortunately if he is stuck in the middle
Of the desert, he may have to risk driving it to atleast pavement. Doubt a tow truck will come in the dunes for him.
LarryB
Larry
Calgary, Alberta
2018 JL Sport 2 dr
My 2 cents … if you don’t have to drive it, don’t. Who knows what damage may have been done. If you have no choice, do what you must, but why risk it if you have the option.
Glad to hear you made it through yourself in tact … you can always buy another vehicle.
