What Tailgate Table do you run?
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
On the rockslide, it looks like the top shelf can be left up? I'm thinking what happens if you want to put a 2-burner stove on it, it looks like the top shelf would be in the way.
1996cc
Oregon
22 JLUR 392
Any idea if this will fit under a Tuffy security enclosure? I've been trying to study all the pics online and it appears that it may clear.
My Front Runner shelf fits under my Tuffy enclosure just fine. I think they would all fit, the Tuffy matches up with the height of the bottom of the rear glass.
Wapiti
Paul
Eugene, OR
2024 4xe JLURX
Got rear ended a while back, and the plastic trim panel on the inside broke during the impact. Perfect time to add a tailgate table; is there anything out there besides the Outback Adventures one that actually replaces the trim panel?
OminousSkitter
The Ether
Trek Bicycle
If you can wait for the preorder, American Adventure Lab has one that replaces the plastic trim.
EDH_JL
State of Jefferson
2018 JL Sport
I got my RSE tailgate table mounted up, but I think I might fiddle with it a bit this weekend. The table itself is fantastic but I'm not 100% sold on the mounting since it just uses the three holes at the top of the table with a standoff spacer and nothing the bottom. I think most tables are mounted this way so it's not a knock on RSE, I just want it more secure.
Jeep Wrangler JL What Tailgate Table do you run? IMG_20200409_174013
Jeep Wrangler JL What Tailgate Table do you run? IMG_20200409_175110
Either I am going to "clearance" the tailgate panel to get it to sit flush against the tailgate or remove it and rig up a thin metal or plastic patch panel and fasten it at the bottom as well.
Jeep Wrangler JL What Tailgate Table do you run? IMG_20200409_175324
Adamoni
2020 Rubicon Recon (2.0T w/ eTorque)
Well, here it is! 15 minute install. 20 if you're a dumbass like me and put the o-ring on before putting the screws in the table. Once I sorted that out, it was super simple. I think it is an awesome table. Way bigger than you'd expect. I have a 17" Blackstone grill coming on Friday. Can't wait!
Very nice. Does it rattle much when driving?
IndustrialAction
Patrick
Slower Lower Delaware
2019 Wrangler JLUR
Nope, no noise at all. The magnets are pretty strong and it all comes together in a nice tight package
IndustrialAction
Patrick
2019 Wrangler JLUR
Yes, the top can be left up. I got a 17" Blackstone griddle for mine. Fits perfectly with the propane attached
IndustrialAction
Patrick
2019 Wrangler JLUR
I have a 17" blackstone as well. Mine has the grease trap on the back. Is yours on the front? Do you have a photo of the griddle on the RSE table? Have you had any issues leveling it?
Mine is in the front. I don't have pics yet but I'll post when I do. The feet on the griddle screw-in so it should be easy to level as long is it isn't crazy off from the start
echo17
Elliott
Sydney, Australia
2019 Jeep Wrangler Rubicon - Sting Gray
When you have the top shelf open/standing up, is it actually stable like that? Or is there a risk of the top shelf falling back down into the horizontal position? Thanks!
IndustrialAction
Patrick
2019 Wrangler JLUR
It won't go anywhere. The shelf is stable.
EDH_JL
State of Jefferson
2018 JL Sport
Made a brace from the existing threaded holes at the bottom of the tailgate to the existing holes in the bottom of the RSE table. Big reduction in movement by having the bottom supported.
It's just some scrap aluminum strips wrapped in electrical tape (in case it rattles), but does the job.
Jeep Wrangler JL What Tailgate Table do you run? IMG_20200419_165130
