What is this warning light??
Birdman
Frank
Vancouver Canada
2018 wrangler JL
Hey All,
have a 2018 Jeep wrangler JL Sahara and this light came on could not find the meaning anywhere? Might be cargo light but I don’t have one then I noticed the wires from the defrost in the rear window was off could this be that? Anyone seen this before?
Jeep Wrangler JL What is this warning light?? IMG_8647
Jeep Wrangler JL What is this warning light?? IMG_8646
ELJL
Ed
Fairfax, VA
22 Wrangler Unlimited Rubicon
Ummm the cargo light is on the roof/ceiling of the cargo area?? Right??
google it and youll find a few vids for aftetmarket parts for it
Birdman
Birdman
Frank
Vancouver Canada
2018 wrangler JL
you need to take a shower
did you check saved message last page of dash screen? could be more info.
Nope clean as a whistle lol. Checked that thanks and no messages, no lights out nothing it’s weird and my cargo light works.
Birdman
Birdman
Frank
Vancouver Canada
2018 wrangler JL
Correct and the cargo light works and is on and that’s not exactly what the symbol looks like
jludave
The Isle of Long
IT Manager
No. That broken connection is a separate issue.
We don't have anything in the JL that would normally trigger that light. Are you still running on your original OEM/factory battery or batteries (main and aux if you have one)? The stock battery/batteries are known to only last about 3 years. Past that and they cause all types of weird electrical issues. If you are on your original battery/batteries, you are due to change them asap. You can change the main and choose to replace or bypass the aux battery if you have one.
Birdman
Birdman
Frank
Vancouver Canada
2018 wrangler JL
Nope replaced both of those batteries.
HK1s
Canada, Montréal, QC
23 2dr sport 3.6etorq AT
Jeep Wrangler JL What is this warning light?? 1692227319211-png
There is one vehicle sharing the same dash so I went to check the gladiator manual and this is apparently the cargo bed light. Your JL could evolve into a JT.
I don't know if you can turn it off, I tried in jscan and JL does have the bed lamp toggle but nothing happens when I tried to switch it on.
The dash is not receiving correct signal, all the dash light is actually just a flag. Eg. I can switch on start/stop light when the engine is running.
Birdman
Birdman
Frank
Vancouver Canada
2018 wrangler JL
Interesting I’ve not done anything to trigger this but I will check that thanks.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Did you check your dash light/cabin light adjuster? Left of steering wheel. If you happened to move it into an always on position maybe that is the problem? Or I could be way off....just throwing out ideas.
Birdman
Birdman
Frank
Vancouver Canada
2018 wrangler JL
Thanks yep checked no that.
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
Is this what that second dimmer wheel does? haha.
