What is that CLUNK?!?!?
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
I've been chasing an interior clunk for some time now. It only seems to sound off when there is some sharp vertical movement, such as a bridge deck transition or a tar seam. It sounds as if it is coming from somewhere near the passenger rear door, near the plastic interior panels as if some heavy metallic object is bumping against one of those panels.
I've checked everything top and bottom, from the underside of the JL to the rollbar panels, tire carrier, suspension, exhaust, etc... and I have emptied everything out of the rear storage cubby. No luck so far.
My next step is to ride in the back seat and have the Domestic CEO take us for a ride so I can try to pinpoint it. If that helps me narrow down the possibilities I may be pulling interior panels.
Anyone here been plagued with something similar? Did you find anything? I'll share what I find, if anything, in case it helps other JL owners here.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
This worked for me. The video shows a JK but it works on the JL also. T
roaniecowpony
Retired Engineer
JL MADDOG
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Thanks for the info. I'll go check this out. It looks like he sort of split the difference between the forward most and rearward most position on the latch.
NMPirate
Jim
2017 JKU Rubicon Recon
King Shit of Turd Island
I have also heard of some people having the jack moving around in its storage area. Check that also.
JL MADDOG
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Thanks for the tip. I have cleared all of that apparatus out of the rear compartment.
JL MADDOG
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Try lubricating your door latches. I use DuPont Teflon Silicone Lubricant Aerosol Spray.
Thanks for the tip. I've lubed latches, hinges and even used some RV slide lube on the rubber seals around the rear window and tailgate. No joy with any of that.
I appreciate the input!
jhackathorne
Denver
'21 JLUR
Does yours seem like something sliding at all? And is yours just vertical movement? I have something similar it sounds like, but mine is whenever I turn left it seems like the rear slides right. Almost like the rear end has spun out and regained traction, but the Jeep is under total control. I've checked the above items as well and had no luck.
JL MADDOG
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
