What adhesive will work.
Shub_32
PA
21 Runicon
Broke the plastic ebrake trim. I’ve tried everything. Can’t order the part . Someone has to know what adhesive will stick to plastic. I’ve tried everything
madscientist
middle earth
20 Wrangler 3.6 AT
If you can add a photo, it might help get some more ideas. I'd suggest a plastic glue like:
Locktite Plastic Glue or Testors Plastic Glue
and a backer, if possible, to provide additional support and rigidity to the repair.
Shub_32
Shub_32
PA
21 Runicon
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
If it shows a reference number (20) on the diagram doesn't it still have a part number that can be ordered?
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Solvent weld it.
Shub_32
Shub_32
PA
21 Runicon
I ordered that part number but they sent me the front half of that piece. The piece I need is not available even thought the diagrams show it. Apparently you have to order the whole console to get it. I just tried two more adhesives with no luck. My next try is plumbing cement. It’s the only one that says ABS Plastic.
I highly doubt that part is made from ABS. I believe it would be made from high density or UHD polyethylene or possibly polypropylene, which is difficult to glue.
If you cant fix it, there are some JLs being salvaged out online. I've looked at some. You should be able to get what you need .
Shub_32
Shub_32
PA
21 Runicon
Nope. Tried everything. Hated to go this route but it’s the only way. Isn’t pretty but no one will know. Makes me mad my Jeep has only 13000miles. I’m gonna put spacers between the screw head and bottom of the console. Only PITA is I have to remove the console to get underneath.
Jeep Wrangler JL What adhesive will work. B2E8E6D4-790F-48A4-841F-96B8E71F03E3
Jeep Wrangler JL What adhesive will work. F310B130-44D7-4BC4-9FEE-DE9D327F72E8
GtX
Illinois
2020 JLUR 3.0D
That is a MacGyver solution right there!
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
I broke the same part on mine last year. I used the epoxy putty that comes in the tube made for plastic. The kind you break off a piece and knead the two parts together. I stuck a small piece where it broke and held it in place until the epoxy hardened. It worked like a charm.
Shub_32
Shub_32
PA
21 Runicon
I’m surprised it worked. I found out that there’s no adhesive that will work because of the type of plastic. It’s almost $400 to buy a new console with that piece on it. Don’t know why you can’t buy it sep.
GtX
Illinois
2020 JLUR 3.0D
I know of no polymer that can't be glued, bonded, fused, or welded.
madscientist
middle earth
20 Wrangler 3.6 AT
If you cannot order a replacement, then hit up a junk yard or ebay for a used part.
