Tier1Gear
AZ
2020 Willys Unlimited Wrangler
Awesome build and pictures!
@Brian0128 share any thoughts on the XG Cargo Gammas? Thinking of grabbing set for my JL!
xj_scuba
Rhode Island
JL
I've got them and love them. Adds a ton of storage in otherwise dead space. I also use the space between the bag and the window to wedge a tree saver on one side and a tow strap on the other. The Bartact seats also come with two small molle bags that I installed on the Gammas, they are perfectly sized to hold emergency ration bars and emergency water bags.
drvn
NOYFB
2020 JLU, 2014 JKU, 2005 TJ
I have them bought and installed. I'd say nice overall and a good use of space. Keeps things from sliding around in the back. My only complaints are that XG gammas are relatively expensive and they only come in one color. I painted mine.
Cheers!
Jeep Wrangler JL Warthog JLUR Rig Journal 20200919_164154
Jeep Wrangler JL Warthog JLUR Rig Journal 20200920_083737
Tier1Gear
AZ
Cheers!
Awesome pics! They look super clean and look like they make awesome use of the "deadspace" up there! Thanks for the info
CaddyshackGopher
North Dakota
2019 Sting Gray JLUR
We went to the auto skills center on the local military base to use the lift and alignment rack to install the Synergy LCA’s and the Synergy front and rear track bars.
I also have e the AEV 2” Spacer lift on my JLUR. I’m running 35’s and really like how your 37’s are sitting in the wells! I’m running 8.5 caster with my Teraflex Sport LCA’s. Do you know what length your adjustable LCA’s were set at to achieve 6.5 range caster? Thanks in advance!
Brian0128
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
I started at 24.5” but had to do an additional full revolution of the adjuster once mounted an on the alignment rack.
Chief_Dan
Tennessee
2020 JLUR Stingray
Very nice!
The AEV Savegre II wheels are the only wheels I have liked so far, other than the OEM Rubicon wheels. So, I'm happy to see what they look like on a Sting Gray JLUR. Looks like a fun build.
:like:
Mmaengine
TJ
Easton, PA
2019 JLU Sahara
Great Post! How did you like the Off-road 101 class? Would you recommend it?
Brian0128
Brian0128
Annapolis, MD
Engineer
I recommend all of Kyle’s courses. It’s actually very affordable to do a private 101/201 2 day course. You should look into it.
conFUcius
Stephen
North Carolina
2024 Supra MKV 3.0, 2024 392 JLUR
Medical Affairs
We went up to Tuscarora State Forest in PA to check out the fall foliage today. It took about 5 hours to do 65 miles on gravel.
That looks phenomenal, I’m certainly more interested in overlanding vs. crawling. Would you say this is worth the drive from NC? The whole trail is 65 mileson gravel? Could start planning to make it up there next year.
Brian0128
Brian0128
Annapolis, MD
Engineer
John from
That looks phenomenal, I’m certainly more interested in overlanding vs. crawling. Would you say this is worth the drive from NC? The whole trail is 65 miles on gravel? Could start planning to make it up there next year.
If I was coming up from NC, I would most likely buy all of the Purple Lizard maps for PA and link a 7 day trip together.
Brian0128
Brian0128
Annapolis, MD
Engineer
Adams Jeep in Aberdeen, MD gave us a call after the 1st of the year and replaced the aluminum steering box with the new steel one under the TSB that we had scheduled at the end of 2020. The Jeep steers significantly better on the highway at 70mph.
jbzonda
Steven
Melbourne, Australia
2021 Wrangler Night Eagle
So glad i found your build. Ive been doing some heavy research on my wheel choice for a couple of weeks now, I think im gonna go with the SAVEGRE II's now they look so good on the Sting Gray.
