Valve stem failures
Pcherron
Phillip
Wrangler
I have had the valve steam fail twice on the same tire. Once after adding two lbs of air and once after removing a couple. I am wondering why this may be happening on a specific tire and what could be done about it. Someone told me metal stems weren't and option...? Is there a recommended kit for changing them?
35 nitto r.g. on fuel ripper
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
What is failing? The rubber section going through the hole? Or the valve core in the stem?
Pcherron
Pcherron
Phillip
Wrangler
First time you could see the stem was cut on the outside. Second time I couldn't see anything. And of course the tpms light is now blinking after getting it replaced yesterday.
OhioJeeper
Central Ohio
6 JL's and a Gladiator
You can replace the stem, or the whole unit. If they replaced the whole unit, they might have put in the wrong frequency unit. I believe there was a change around mid-21 on those.
roaniecowpony
Retired Engineer
Buy good guy stems. Don't skimp on them. The cheap ones tire shops use often give you problems. I had all 4 go bad on my truck about a year after having tires installed. They all failed one at a time, within a few months of each other, just driving. The rubber dries out and cracks on cheap stems.
Pcherron
Pcherron
Phillip
Wrangler
Did not find via Google search. Do you have a link handy?
Kahunadave
Orlando, FL
2020 JLUS 2.0 Etorque; 2015 GrCherokee ltd 2wd
Auto Lending
im in the process of changing out Wheels and Tires and picked up a set of Valve Stems from NAPA auto parts.. $3.xx each. and will install myself before taking to DT to mount the tires on.
