Upgraded Brakes Need Help
Dalvarado55
Arizona
2018 Jeep JLU Sport 2.0, MC 3.5" lift, Rubi Axles
Upgraded brakes to Powerstop Z36 rotors, pads, brake line extensions, and upgrade front Sport Calipers to Rubicon Calipers. Brakes feel the same if not maybe softer.
I have a 2018 JLU 2.0, 3.5 MC game changer lift, and on 35s.
It was suggested to have the dealership flash the brake module?? Is that a thing. Person suggest the module is set at the pushing brake fluid for the Sport caliper and not the upgraded Rubicon calipers.
Any help or suggestions? Please?
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
First you should do a ABS bleed. You may have air in the system and the only way to remove it is with an ABS bleed.
Also a brake upgrade like Teraflex Delta brakes. The Delta brake are amazing. It is what I finally went with. They use Toyota Tundra pads and anti knock back springs behind each caliper piston giving you a amazing brake pedal.
Here is a video explaining how air may get into the system.
~Blue392~
Maryland
2022 Jeep Rubicon 392
I know a lot of people here will cringe about this one but…for Lotus Elise/Exige owners…and others I’m sure…one trick is to find a stretch of empty road, build up some good speed and then slam on the brakes hard enough to engage the antilock brakes. It causes the valves to activate and push all of the air out of the module.
Dalvarado55
Dalvarado55
Arizona
Will that actually work? How fast do I have to go?
Dalvarado55
Dalvarado55
Arizona
Thank you. I’ll try that before going to the dealership
Original_Junior
Georgia
2022 JKURXR
Did you follow Power Stop's instructions for break in prior to regular use? Those steps they outline are critical.
Dalvarado55
Dalvarado55
Arizona
Yes I did.
~Blue392~
Maryland
For pavement it’s usually a pretty spirited run before hitting the brakes. I was thinking of this from a track car perspective but @azwjowner makes a good point. Jeeps are made for off-road. It shouldn’t take much effort to get the antilock brakes module to kick in if you’re off pavement.
Dalvarado55
Dalvarado55
Arizona
Did this last night 3x on a dirt road. Immediately after the pedal felt stiffer with a better response. I think it worked. Thank you for the help.
roaniecowpony
Retired Engineer
Jscan, Taser, and many other scan tools will provide procedures to activate abs for bleeding it. Its more effective than slamming on the brakes.
zouch
Berkeley, CA
XJ, JLUWD
really? Tazer will do this? i've never found that in the instructions. are you certain?
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Tazer (Zautomotive) does that now? I think I asked for this Tazer mini feature a year or two ago.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
Yeah, I thought only J scan did this outside of the dealership, of course. I’m curious about other options though.
roaniecowpony
Retired Engineer
I thought I had heard this. But, I'm probably mistaken.
