simpleJL
- Kyle
- Nov 29, 2017
- East Bay, CA
- '18 JLUR
I recommend the F106S, as it has a short nipple. (That almost sounds sexy)If anyone is interested in the Fumoto Drain Valve you'd replace your 2018 Wrangler JL, OEM oil drain plug with the Fumoto F106 M14-1.5 Drain Valve
Pick a F106 with nipple or without nipple. When installing be sure to use just the provided fiber gasket and just that fiber gasket. Do not over tighten. Be sure to use a lever lock on the installed Fumoto Drain Valve.
Google search the Fumoto Valve before you buy / install. Read what other Wrangler owner's say about the Fumoto Valve.
Less likely to catch it on a rock and rip it off.
