Trickle Charger?
SadRobot
Los Angeles
2025 Prius LE
Yes, indeedy!
Much appreciated. Where to actually hook on the negative clamp has been up for debate for the past 4 hours so happy to put that to rest. 🤣
Just for educational purposes why does putting it on the post keep the IBS calibrated as opposed to where I had it before? The Noco manual wants me to ground it to the frame but I think that's just so if it sparks the potential for fumes to ignite is less?
Jeep Wrangler JL Trickle Charger? 1040779-a7bcd23de7473e2b44a1fb9a5e7f512
Now that it's hooked up how long should I expect for it to be fully charge and just be maintaining? Jeep was last driven on 12/9 but I did turn it over a few days ago for about 20 minutes but did not drive it.
THAW
Foster
23 JL4DrRubicon
With the charger clamp connected like you first had it, between the battery terminal/post and the IBS ("current sensor"), the charge current doesn't travel through the IBS (it's basically bypassed), so the IBS doesn't know the battery is being charged.
Jeep Wrangler JL Trickle Charger? 1000005691
[It's even worse if there's an AUX (ESS) battery connected, because the IBS will think the charge current to the AUX (ESS) battery is a discharge current for the CR[an]K/main battery (while both batteries are actually being charged).]
When you moved the charger clamp, the IBS ("current sensor") is between the charger clamp and the battery terminal/post so the IBS can track how much the battery is charged.
Jeep Wrangler JL Trickle Charger? 1000005692
Yes, I believe the body/frame ground suggestion is for spark safety when first attaching the clamp (rarely an issue). A body/frame ground position for the charger negative clamp does allow the IBS to properly track charging.
How long the battery takes to charge depends on how discharged it is, which is hard to guess. Unless your battery was really discharged for some reason, a 5 Amp NOCO charger should show the green light indicator within a couple hours max.
SadRobot
Los Angeles
2025 Prius LE
Thanks for that explanation. I guess I'll check back in a few hours. It's been charging for about 2 hours now and still blinking less than 25%.
BRuby
Chilling or working out at 60+
JLUR Benz Porsche-M Subie-M
Hmm? This is a bit weird.
As some are aware we have 2 CTEK 3600, 1 NOCO 5, 3 NOCO 7200, and 1 NOCO 10. We use them all 24/7 365 days a year. The 2 CTEKs are a bit long in the tooth as they predate NOCO. They were top of the line smart back in the day. Being recommended and rebranded sold by Porsche.
Now for charging after 2 hours with less than 25% blinking. Seems that your battery was not charged or jeep driven immediately beforehand. Since whenever we hook up using the NOCO 5 on our Jeep aux alone - it goes through the charging stages and cycles in about 40s max.
Yeah we are an outlier who has been charging our jeep batteries separately. Weird but it works 100% a charm for us after 7 years running original 2018 OEM many deemed crap batteries.
Anyways as a suggestion - maybe properly load test your batteries as well. But do whatever you want. It is your jeep.
SadRobot
Los Angeles
2025 Prius LE
I just went out to check and it is still flashing below 25% and it's been over 4 hours so maybe something is wrong. I'm not sure if I should let it keep going or just unplug it all together.
edit: I disconnected the Noco and I'll have to deal with it tomorrow when it's light out. Jeep does start up just fine. As a side note I don't have an AUX just the main battery.
Sidewalk
Josh
Riverside, CA
JLR
I added a cheap tender to my grandma's Accord years ago because she only drove once every couple of months. Every few times she needed to drive, the battery would be dead. I used weather proof connectors so it could plug in easy, but she could just drive off and not worry about damaging anything if she forgot (fortunately she stopped driving entirely soon after anyway).
One of these days I'm going to do the same to the Jeep. I often leave it sitting for a week or two at a time, but it always starts fine.
My van has solar panels going to a house battery. Any remaining juice after the house battery is fully charged goes to the starting battery. When it is parked with the fridge off, everything stays fully charged and I never have to worry about it. In the shorter winter months I barely get enough solar charge to make up for the fridge, unless a shadow from a tree blocks a panel.
BRuby
Well after using all these various 4 smart chargers for decades now - have learned a bit about some of their charge mode individual idiosyncrasies. So one will charge - where another will not. In some cases absolutely not. In some cases absolutely. Just depends which one we hook up. So have concluded each one has a slightly different charge profile and protocol.
When one does not charge - it indicates that a battery is slowly degrading to the point where it is slowly dying - and will die. Sometimes soon. Sometimes in a few years. Just depends. Roll a dice.
Because we use 4 different model smart chargers - hooked to always and only 1 per battery - we can track exactly when 1 dies or can live for months or years longer. Years our batteries do in fact live - 12 and 14 years long respectively based on the last 2 that have died. Yes we properly load test as well all the time. Also desulfate all the time.
Now for your battery on N5 - would try again like you planned and leave it sit charging. If it fails again try a N10 or more powerful smart charger. If it fails again try a real load test with a heated element and needle scale. Not the digital BS. If it can no longer smart charge with any CTEK or NOCO it is dead or will die soon. But since yours starts you are still ok. Take care of the damn thing by putting it on a good smart charger and it will give you a lot more trouble free starts.
Now if you can get it to properly do a full charge - go ahead an immediately desulfate.. But again do whatever you want. Just trying to pay forward. We 100% love our smart chargers. Yep fantastic devices. Zero guessing. Zero speculation. Zero wastage. Full use of every battery we have. None of the 1, 2, 3, 4 year BS so many moan about. Simply take care of your batteries - and they will take care of you.
THAW
Foster
23 JL4DrRubicon
Is it the @SadRobot curse, or is @Terrymo playing some elaborate prank on you?
Well this just has to last me a few months so I don’t need anything too powerful. Just enough to keep it from draining.
If you don't have a 15 amp charger, this is your opportunity to just have one purchase/ine device. All modern battery chargers will trickle charge.
SadRobot
Los Angeles
2025 Prius LE
In this case, I hope not. I think she’s at her wits end with the continuing Jeep drama.
Any sane person would have offloaded this Jeep years ago so I really don't know what's wrong with me. 🤷‍♀️
In good news I let the Noco charge overnight and it's blinking green and in maintenance mode. Turns out I just wasn't patient enough (which may be part of the answer to the above question of what's wrong with me). 😂
Jeep Wrangler JL Trickle Charger? IMG_0861
Terrymo
Terry
2023 JLURXR 3.6 ET
Good news! I thought maybe your UPS guy threw the charger like a football up your stairs and broke it. They do have priors with you. 😂
SadRobot
Los Angeles
2025 Prius LE
That was my first thought when I got the notice you had sent the box via UPS. They don't like me around these parts. 🤣
