Transmission Adaptive Learning Reset
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Thanks. I may grab a JSCAN. It shifts hard enough to move stuff in the back, so something clearly isn’t right. No codes though, so they didn’t do anything.
Just be aware if you have done any mods like larger tires and never adjusted for them the shift points will be off but as stated it technically should relearn automatically but that’s in a perfect world
mcjeff
Pittsburgh
2020 JLUR
Thanks. I’m still on stock tires with no mods that would impact the transmission. This is actually part of the reason. I didn’t want to deviate until I get it figured out.
WranglerMan
Will
Greenfield Indiana
If you have zero mods that would affect the shift point I would be suspect there is a possible drivetrain issue but let’s hope thats not the case.
Cat4
Jake
Washington
2022 392 XR
Did anyone get this resolved? Having the same issue.
mcjeff
Pittsburgh
2020 JLUR
Nope. Went to three dealerships a total of four times. Jeep wound up giving me a discount code on a new one because they never figured it out. Traded it (with full disclosure of the problem) and got my replacement (this time a diesel) in October.
  • Like
Reactions: GtX
BuffaloBill
WI
2024 Wrangler 2.0, 2020 wrangler 3.0
What do you think of the diesel, now that you’ve had it for a couple months?
mcjeff
Pittsburgh
2020 JLUR
It "feels" better than the 3.6 did, if that makes sense. In a lot of ways.
I don't know if that's due to a later model year, or added weight, or what. Brakes feel better, steering is firmer, acceleration and torque are better. The only thing I've paid attention to that I used to not have to worry about is the regeneration process (which I wrote a post about and I'll link below). I purposefully picked one with a different drivetrain after running into the problem I had with the 2020 JLUR. I had originally wanted one when I got my 2020, but the exhaust posts scared me off.
https://www.jlwranglerforums.com/forum/threads/regens-after-a-month-of-ownership.82491/#post-1725732
darylm74
Daryl
Oldsmar Florida
2021 JLU Willys
Sr Data Engineer
I know this is an old post but curious about what that shifting felt like? I have a diesel and it is currently throwing a crank shaft position sensor which has already been replaced. Mine feels like it is what I call transmission slap. It jerks you around, but only on up-hill or load (small trailer) acceleration. It doesn't show up otherwise. I am trying to get to the bottom of this as I did a lot of mods (issue existed before the mods) and thought it was related to the fuel pump issue, replaced after the mods (jerking is a common fuel pump issue), but that has been replaced. I feel like I am grasping at straws but so many different possibilities.
mcjeff
Pittsburgh
2020 JLUR
It felt much like a hard downshift on a stick. Would happen mostly on downhill coming to a stop. It would even chip tires and shift the load in back sometimes. I didn’t have any mods that would impact it. It would rev up as well due to the downshift.
it wasn’t a fuel related jerk.
Multihull
Commander Phil
Brisbane, Australia
JLU 2.2 diesel Rubicon
Multihull Consultant, Automotive Drive Consultant
Just use the Jscan app to force a short relearn of the transmission. TCM.
It fixed the issue with my truck, I was experiencing the same issues as listed above. Also if you have larger tyres from stock, eg 37s you need to regear to prevent these issues but make sure you reprogram the TCM with ghe new gear set ratio and then after a few drives do the transmission relearn.
