Trailer builds
Wkaz
MA
2021 Sahara
I'll be building a small utility trailer for the Sahara. Picked up 72' of 2x2x3/16 wall from a plant closing. I've built a couple before but this time I want to use factory jeep wheels. I know I can buy the correct bolt pattern hubs but my concern is the rim fitting over the bearing housing. Does anyone know if I have to use wheel spacers to clear this problem ?
azjl#3
North AZ
try tractor supply
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wheel spacers will cure the hub issue. Size the axle accordingly.
The Last Cowboy
San Antonio, TX
was hoping to stay away from spacers.
They wont cause any issues, as trailer axles aren’t driven or steered. But I agree, I’d rather have the hub of the axle bolted to the hub of the wheel itself.
Try browsing the websites of Southwest Wheel or eTrailer to see if they have hubs that will work.
