Top uses for JScan
AZpueblo
AZ
2019 JLUR, ‘24 JLURX 4XE
I have done tire size, tpms threshold, highbeam dropout. I wish it could disable 3 honks.
I havent done hood alarm, I wonder if I even can. I got manual locks. may I ask where you go to activate hood switch to the alarm?
In Jscan, go to Adaptations>>>scroll down to VTA-Vehicle Theft Alarm Settings>>>VTA Hood Ajar Monitoring on/off
Pape
Quebec
JLU Sahara
Did:
Hood alarm
Tire size
Increased light amount to activate automatic head light.
Play around with drl but ultimately put it back as it was
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
I use this one, it has worked for everything I have tried on my JL and my '15 Ram and '20 Ram
https://www.obdlink.com/products/obdlink-lx/
I bought this one, plugged it in and played with it without SGW bypass harness therefore could only look at settings. Been busy, need to see what all I can get done with it.
ESS is set to disable automatically, but I can turn it back on...via my tune from @bmpcamry09
I want the three honks when closing door with keyfob inside to go away!
Stop ALL the chiming for ACC on, etc.
Enable hood open alarm
Tire size
Want to use lockers at any speed 4H and 4Lo
Keyfob panic button is super annoying too
Foglight drop out with high beams on
TPMS light and pressure settings
DRL settings
Xfer case swap to 4:1
axle swap to 4.56/4.88
ABS Brake Bleed
Pull codes and reset.
OBDLink MX+
https://www.obdlink.com/products/obdlink-mxp/
Cartman
ANDREW
Slovakia
Jeep JL Sport+ 2d 2023
I was also able enable remote start. first I have buy two new keys, then swithed the blades, switched imobilliser chip and then enable it with Jscan. during winter I use it every day to heat up the car.
THAW
Foster
23 JL4DrRubicon
Is this checking the actual health of the 12V battery?
I'm still on my original 12v from the factory October 2021.
Yes the 12V battery. The IBS tracks only the CR[an]K battery, but an AUX (ESS) battery can/does have an effect on some of the data (you have a 4xe, but just sayin').
The starting point is:
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor State of Charge - (%)
That'll tell you how charged the Jeep thinks your battery is. Don't be surprised to see it around 80%, but if it's below 65% some features might be disabled - ESS certainly will be for Jeeps that started life with an AUX (ESS) battery.
This next one will give you an approximate idea of the battery's resting voltage (note that it only has data under certain conditions, and often shows a default value of 15.23):
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Voltage Before LIN Wakeup - (V)
You can also look at IBS Voltage, Current, and Temperature to observe real-time charging/discharging:
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Measured Voltage - (V)
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Current - (Amps)
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Temperature - (F)
Residual charge can be divided by SoC % to get an idea of what the Jeep thinks of the battery capacity.
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Residual Battery Charge in Ah - (AmpHrs)
And, you can track internal resistance for long-term trends (a spike could indicate a battery health issue).
MODULES -> Body Controller -> LIVE DATA -> Intelligent Battery Sensor Resistance at 100% SOC and 25 DegC - (mOhms)
Graphite JL
Romeo, MI
2018 Sahara Unlimited
I use the OBD Link adapter, If you use Android Auto, you can have it display live data on your radio screen.
Pismo61
Temecula,Ca
2026 JLURX
Should have sticky on Jscan.Somethimes getting to what you need to adjust isn't always a clear path.Enabling the aux, switches took me a few tries as an example.
Pape
Quebec
JLU Sahara
That’s what I meant when I mentioned I was disappointed in my first post. I got the avenger light to go away, but as it turns out, the ESS still functions even though it is disabled in the software. There may be something I missed or misunderstood, but I went ahead and bought the eliminator and that finally did the trick. Something to do with how the hardware is configured vs the software. I was happy to use it to get rid of the light. My primary reason for getting JScan was my tire size so everything else is an experiment.
You also need to unplug one of the 2 hood monitoring plunger to get the start stop fully disabled with jscan
Cartman
ANDREW
Slovakia
how? jscan could be in android auto?
Graphite JL
Romeo, MI
Not JScan, but the software that comes with the OBD Link dongle.
I didnt try it with JScan yet, didnt even think about it.
Jeep Wrangler JL Top uses for JScan 20260704_195707
ag4ever
‘82 CJ-8, ‘82 CJ-8, ‘83 CJ-8, ‘26 Moab 392
When I had a 4xe, I often used it for live data on battery status and temperature.
For the 392, I changed the locks setting, added hood sensor to alarm, and a few other light settings.
I have been disappointed in the lock setting. On my 23 I could unlock all doors with the tailgate handle when set to driver only unlocks driver door. On the 26 the only handle that will unlock all doors is the passenger door.
Also, the security gateway was MUCh easier to access on the 23, they moved something that made the 26 way harder to access.
