Tire weight in decision process?
Notorious
North Texas
2000 TJ Sahara
I'm trying to get some 37's that are close to being true to size
Goodyear Duratracs are available in 37” with 20” wheels. Not sure how much they weigh but as far as I know, these are true to size. For reference, the 35” tires are 61 pounds.
Shenanigans
NorCal
JLU Rubi
I've run BFG KM2s on my last two rigs. I was all set to try the new KM3s this time, but there's a long wait before they come back into stock. I like Toyo and Nitto mud terrains, but the Mickey Thompson Baja MTZ P3s look good as well. At 66lbs they're a good dozen pounds lighter than the others. [the Nittos are a porky 80lbs] Any thoughts folks?
the original mtz was a great tire on the rocks and it performed great in the mud. I only put on a couple thousand miles over the 10 years they were on my trail rig so not sure about tread life. It was on par with the original mtr which is preferred by most in regards to the current mtr.
rickinAZ
rickinAZ
Phoenix
2026 MOAB 392
The lightest high quality tire that I've found are the Mickey Thompson Baja MTZ P3s. I'm basing the quality on the Discount Tire rating. They have two 35s rated as "best": The Mickey Thompson and the KM3s. The KM3s weigh 75lbs and the MT's are 66lbs.
Amaruq
Atlanta
JLR 6spd
I just went with 34" instead of 35s and weight was a huge factor for me. My new Toyo A/T IIIs weigh in at only 59 pounds. I didn't wish to risk needing to re-gear for acceptable performance and I don't have enough real world experience as this is my first Jeep "build" to know for sure one way or the other. Rotational mass and basic inertia seem significant.
Even the cost of added weight on the tail gate was a consideration for me.
The 34” C AT3’s? How are they?
pangmaster
Nathan
Mid Michigan
2018 JLR
Enterprise architect
Weight has been a significant factor in my decision process as well. I have run KOs for years and now the KO2s and like them a lot, but a good MT is where I’m going next (and I’m so over how much gravel the KOs always pick up).
I’ve had good success with the original MTRs, but they aren’t top of my list anymore. I looked hard at Toyo MT but that would have been about 35 lbs above stock per tire with my wheels factored in. Went light on my wheels as well.
At the end of the day, I think I’ve settled on STT Pros, which are not too much heavier than 315 KO2s or Duratracs. But I still haven’t pulled the trigger.
But for all the Toyos and Nittos I see on Jeeps, clearly not everyone cares too much about tire weight.
kantho
Karl
San Marcos, CA
2018 JL Sport 2 door with premium soft top
Well I'm liking them so far on the street. They are quiet and I like the look. Perhaps a bit more subtle than 35's would have been which is perfect for me. I'm using the stock spare bracket and the tire just rubs slightly on the bumper. Not sure if I need to modify that.
I have yet to go off road though so that'll have to be some future testing. Haven't found the right tire pressure yet either and working on that lowering a pound so so every couple days and driving awhile. I also just installed a Tazer Lite to adjust the speedometer to the correct tire size so I'm playing with that a bit too right now.
rickinAZ
rickinAZ
Phoenix
2026 MOAB 392
I recall reading that unsprung weight has a 10:1 impact versus weight reduced from the vehicle itself.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
20s would be detrimental to any weight saving afforded by the tires. Looking at rotory forged wheels and possibly Falken MT. The tires are about 73 lbs each, which is pretty good for a 37 that is strong, and the wheels should be around 30lbs each. Not exactly super lightweight compared to stock, but for 37s that can take some trail and rock abuse, it ain't bad.
InvertedLogic
Denver, CO
20 JTR
Weight is definitely a factor to me. But moreso for the whole system. It cracks me up when one gets focused on tire weight then puts it on 35-40lb wheels (looking at you, Black Rhino). I'll stick with my OEM 22.5lb wheels until I need a 8.5" wide in which case a nice aluminum wheel should come in around 25lbs max.
aeonixx1001
Kim
Arizona
2020 Jeep JL
what tire pressure is everyone running for BFGood Rich K02's 285/75/R17. Man the internet is all over the place. I figured my friends here would tell the right answer. I do use it as a daily. One guy told me 40 psi and another told me 24 to 26. I have the same set on my Toyota Tacoma and we stop by discount tires to get the pressure checked (Arizona, ya never know) and they always put 37 psi in. I did the calculation for weight and load and I come up with about 32, so I always let the air out and they are fine great treadwear. But just curious what you guys are running.
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
Yes weight is a killer for jeeps.
I keep mine as light as possible
for tires/wheels
procomp wheels for now 29lbs which is okay. Id like to get something down to 26
tires ive had, duratrac in 315/70r17 at 61lbs. So thats 90lb total.
Now I have mickey thompson deegan 38 MT in the same size at 63lbs. Very light mud terrain, so far have worked very well
aeonixx1001
Kim
Arizona
2020 Jeep JL
for tires/wheels
Yeah I am now 59 lbs
UrbanCowboyAZ
Sean
Scottsdale, AZ
‘20 JLURD, ‘02 TJ
Real Estate
Very important on my 4.0 TJ with 37’s that weighs at least 1000lb more than stock. Less so on my torque monster diesel I’m waiting on.
I had 37x12.5r17 Trail Grapplers that were on my TJ when I bought it. Had them for 3 years and 20k miles (they probably went 40-50k). Great tires, but really heavy at 84lb. When they wore down, I just replaced them with 37” Mickey Thompson MTZ P3 that are about 10lb per tire lighter. They are also a great tire and have performed just as well on road and off, while being lighter. That being said, I specced my JLURD with 35x12.5r17 Trail Grapplers, which they say way 80lb, but I’m not as worried because of the torque that the diesel makes.
pangmaster
Nathan
Mid Michigan
2018 JLR
I’ve seen similar claims but also others that are lower than 10x. But at any rate unsprung weight it’s not to be overlooked in my opinion
Pig-Pen
Banned Camp
2018 JLU
jabroni
it is certainly a factor for me.
i have lightweight wheels on 315/70/17 Patagonias. i recently tried out a friends BFG KM3s in 35/12.50/17 on the same wheels. the tires were noticeably heavier; in driving and manhandling. just putting them on the jeep and on the spare tire mount was a bear. i could feel my jeep being more sluggish while driving around on them (slightly). also quite a bit stiffer ride/sidewalls. it was not as pleasurable to drive as it is on the Pats.
unfortunately i didnt weigh the wheel/tire combo on my $$ scale but they were definitely heavier. 5-10lbs each at least.
